SuperCrew
Air Conditioned Door Handles
Old Aug 6, 2002 | 03:01 PM
Lost Pup's Avatar
I was curious, with the AC on and running, are your door outside door handles cool or cold ?
I can actually feel cold air blowing across my hand when I go to open the door from the outside handle.
Old Aug 6, 2002 | 03:10 PM
larryp's Avatar
Normal operation. Cab air exists thru the door handles instead of having vent holes somewhere else.
Old Aug 6, 2002 | 03:42 PM
dcovell's Avatar
Hmm intresting didn't know that. It is truley amazing what you can learn here.
I guess you have to or the cab would pressurize too much and your ears would explode! Or just be an annoyance more likley.
Old Aug 6, 2002 | 06:47 PM
Lost Pup's Avatar
Ok
How does the air get into the door ?
Old Aug 6, 2002 | 06:57 PM
S'CrewLoose's Avatar
Speaker Grilles?
Old Aug 6, 2002 | 09:25 PM
Rockpick's Avatar
Moderator &
The door itself does not exist in a vacume and thus, there is air inside.
RP
Old Aug 7, 2002 | 07:46 PM
Lost Pup's Avatar
I have never had the door panel off.
Do the speakers not cover or seal completely to the door ?
Is the door panel speaker opening larger than the space actually needed for the speaker ?
Open element speaker ?
I get that the door is not in a vaccum but I thought the speakers would seal to the door and as the cones move use the door space as a chamber...Its just that the all the door handles exibit the cooling effect.
I wonder when the heat is on will any ice or snow on the door handle will melt ? Lets see..2003 F150 ..new...improved..heated door skins..the ice and snow melt away.
Oh well I had enough..info overload. Thanks for the replies.
Old Aug 7, 2002 | 08:06 PM
screwfun's Avatar
There are more holes in the door besides the Speaker. You would never be able to adjust the window, replace the motor, without other holes. Therefore there are other places for the air to get throught the door and out of the door handles (or any place that is not sealed). All cars/trucks do it.
If the car/truck was air tight you would have a hell of a time shutting the door. The doors would have to be sliding to be able to shut.
If you do not like the fact air comes out of the door handles turn your A/C to MAX.
