SuperCrew
Door problem
Old Jul 24, 2002 | 05:12 PM
fanosix's Avatar
Angry Door problem
Every time I go arong a right turn my door ajar light comes on.
The door is closed and unobstucted.
IF I pull on it it goes off, but comes on again in about 2-3 seconds
any input or am I dealer bound?
Old Jul 24, 2002 | 06:13 PM
jryager's Avatar
Probably Dealer bound if it is under warranty. The door fit is adjustable (usually adjusted to tighten the fit to eliminate wind noise). Anytime you corner, the frame undergoes stress and twist to some degree, even when you accelerate it does. One of three things will probably fix it, adjust the door ajar sensor, adjust the door git, or replace the sensor.
Old Jul 24, 2002 | 07:32 PM
TexfordD's Avatar
spray WD-40....
into the latch assembly at the end of the door,that will fix it
Old Jul 25, 2002 | 11:46 PM
fanosix's Avatar
TexfordD
I tried it and no luck.
I'll let Y'all know what the dealer says
