SuperCrew
Power source for tonneau cover light??
Old Jul 20, 2002 | 12:42 PM
elmn8r's Avatar
Lightbulb Power source for tonneau cover light??
I have an A.R.E. LSII series tonneau cover on my 2002 SuperCrew and would like to add a light inside the cover. Is there an easily accessible 12 volt source that is commonly used for lighting inside topper and tonneau covers??
Old Jul 30, 2002 | 12:53 PM
ELMO4635's Avatar
Lightbulb What I did....
I have the same ARE Lid, and I bought a 2-pak of battery operated flourescent lights from Target for $9.99...
They are about 4" long, run on 4-AA batteries, and even came with the velcro to add them to the truck. I attached them inside the tailgate, on either side of the bed... works great!!
Eldon
Old Jul 30, 2002 | 02:12 PM
screwfun's Avatar
Power to bed
Not without drilling. Had to drill holes for my power.
Old Jul 31, 2002 | 10:31 AM
GSCrew's Avatar
I have a couple of the "tap light" type of battery powered lights stuck with double back tape on the sides of the bed under my tonneau. I was going to wire a light in but considered the fact that it would drain the battery if left on accidentally over night or for an extended period when the truck was not in use. I know there is a battery saver function built in but didn't wish to test this function. just my 2 cents.
GSCrew
Old Jul 31, 2002 | 04:36 PM
jkempster's Avatar
May seem odd, but I used the trailer wiring for my light. I just bought the end that goes into the trailer jack and wired it up to a light. I did drill holes, but could have run the wire longer and come through some rubber gromets at the front of the bed.
Old Aug 1, 2002 | 10:51 AM
Rustyscrew's Avatar
I ran a wire from under the hood, not the easiest, but it works. I also did not drill holes. I ran the wire through the holes between teh tailgate and the bed. There are several on teh side along the taillights. Be sure to add grommets to eliminate chafing. I laso used self adhesive wire clips to hold the wire to the side. Once in teh box, I added a single pole-double throw toggle so I could either have the lights on or use a lighter powe outlet I added. Looks pretty good and is very functional.
