Free SCrew bedliner in Atlanta area
Just pulled out the bedliner (Duraliner - Ford OEM) from my SCrew because I'm getting Line-X. It is the black one, not quite tall enough to fit under the bed rails, so you would need some double-sided 3m tape or something in the middle of the sides.
This bedliner, including the tailgate liner, is FREE to the first person to come by and pick it up. I live north of Atlanta, in the Cumming area.
RamblinWreck or whoever gets your bedliner,
You might check with Duraliner about getting it swapped out with one that fits. When I bought my truck part of the deal was the dealer put the liner in, when I got it they had put one in but it had that problem of the liner sides didn't go high enough. Made a big stink about it and had the dealer put a different one in (three times). Same problem. So I (not ford unfortuantely) finally called Duraliner and found out they had just figured out their mistake and you had to get a liner made after April of 2000. Told Ford to order a new one from Duraliner, not from their parts wharehouse, and verify the manufacture date before they put it in. They got it and it fit a lot better (made Ford replaced it one more time because of the 2 inch diameter holes they put in it for the bed extender mounts. I was there for the second install and made them make the holes right that time). Duraline may replace it... it's probably a long shot after all this time but probably worth the phone call.
Cheleri
Cheleri
Why would I want a new bedliner swap from Duraliner? I just got Line-X put on today. I don't want the bedliner. The bedliner is history. Outta here.
My dealer refused to do anything about the bedliner, since I would not pay for it, and they "threw it in for free" when I bought the truck. I know about the issue, but they would not budge, and I wanted Line-X anyway. Duraliners suck, IMO, even when they do fit.
Thanks anyway, but I'm throwin' it out! Unless someone snags it first, that is. Maybe they can go deal with Duraliner and get a new one.
FREE BEDLINER! COME AN' GIT IT!
RamblinWreck,
That's why I posted to you or "whoever gets your bedliner". Man, what a hardnose dealer. He probably could have dealt with it in a phone call and had a happier customer on his hand.
Best of luck with the line-x. I did the duraliner instead of the spray in simply because when I bought mine, the spray in's were fairly new and I knew a guy that had one that was peeling up and was being redone. I didn't want to go through that.
Cheleri
Cheleri
