SuperCrew
towing a boat with supercrew
Old Jun 25, 2002 | 02:57 PM
Joe D's Avatar
Got a 2001 supercrew 5.4 with towing pkg.do you think I can tow a 25 boat with out any problems or harm to the truck,boat and trailer est. weight 7500 pounds thanks in advance Joe D
Old Jun 25, 2002 | 03:13 PM
LakeSands's Avatar
That is a heavy boat for 25 ft. I have a 20 ft boat that weighs about 3500# and tow it with now problems at all. It is a pleasure to tow with the SCrew. If yours weighs 7k you'll feel a little more strain than I do, but it should still tow it. Most important are your brakes with that much weight.
Old Jun 25, 2002 | 05:34 PM
DAVEMAN's Avatar
Hey Lake,
I think the guy meant that his gross combined weight rating GCWR is 7500 lbs which sould be no problem for him to haul behind his S'Crew.
~DM~
Old Jun 26, 2002 | 12:12 AM
BroncoDave's Avatar
I pull a 20ft aluminum boat with my truck (I wish i could tell you the wieght) and have had no problems. Much nicer than my Bronco, I never trusted the brakes on that truck when hauling. Much more comfortable pulling with the supercrew.
BD
Old Jun 26, 2002 | 01:27 AM
cyberhiker's Avatar
I tote a 17ft mad river canoe ... 55 lbs. no real problems with the 5.4 , but think i should have gone with a F350 , 7.3 deisel Powerstroke
Old Jun 26, 2002 | 06:43 AM
DAVEMAN's Avatar
Hey Cyber,
I don't think you could carry that heavy load without having dual rear tires with the F load rating, I'd be afraid to give different advice for such a demanding application. Oh, and don't even think about getting away with anything less than a class IV or V weight distributing hitch, it's a must.
Let us know when you get all the required equipment and take some pictures so that everyone can learn what the minumun requirements are for towing extremely heavy loads behind a truck.
Later,
~DM~
Old Jun 26, 2002 | 07:19 AM
Joe D's Avatar
you can see boat here
Thanks for the replys here is a way to see boat.
http://www.prolineboats.com/series/sport/25sport.html thanks Joe D.
Old Jun 27, 2002 | 12:30 AM
BroncoDave's Avatar
ok here's my boat--http://www.monarkmarine.com/products/king.html
bd
Old Jun 27, 2002 | 06:57 AM
Joe D's Avatar
do you guys think this is 2 much boat to pull with my 4x2 screw it is 40 miles one way to the coast.
don't want to buy boat and have to get a 250 to pull boat I have been so happy with my super crew thanks Joe D
Old Jun 30, 2002 | 12:20 PM
Mark_911's Avatar
I pulled almost 8000lbs over 300 miles a couple of weeks ago. I never dropped below 60 mph and never had a single problem.
Old Jul 1, 2002 | 11:52 AM
Greg Mc's Avatar
I pulled for the first time this weekend with my Screw. Towed a 24ft enclosed trailer that carrys a race car, total weight 7340 lbs. I towed with OD off at 60 to 65 mph, handled it great. My trailer catches a lot of air compared to a boat so you will probably be okay. My Screw is a 4X4, never pulled much weight with a 4X2 1/2 ton truck. The key is proper weight distribution. I also pulled the same set up with my '98 Expy 4X4 it did fine also but the added wheel base of the truck makes for a more comfortable tow. Hook your truck to the boat and pull it before you buy it, just to make sure you feel safe.
Old Jul 3, 2002 | 04:02 PM
Carolina SCrew's Avatar
You guys need to remember what the GCVW is for these 1/2 ton trucks.
Old Jul 4, 2002 | 02:22 PM
thenry21's Avatar
Back when I was young and we were poor(er) my father used to haul our 28ft Bayliner Sportfisher (used as a charter boat) with my 1/2 Ton shortbed F-150. The boat weighed in excess of 8000 lbs. and completely dwarfed the truck, but the truck would pull it around no problem. The granny 4 speed with 373 gears helped. The new Supercrews are a lot more truck than my old shortbed. It wouldn't worry me to haul a boat like the one you described with my 2001 Supercrew 4x4. Just exercise caution as you should always do, when hauling something.
Old Jul 11, 2002 | 05:05 PM
phinneyt's Avatar
Talking Towing's not the Problem, Stopping might be
I normally tow my 22 Sundeck (4,200lb + 540 Gas/Water + trailer + gear) and have never had a problem with my O1 Screw 4X4 ORP w/ heavyduty tow otions. once you get it rolling it should tow nice. Just make sure you got Surge brakes on the trail or better yet electrical brakes.
Truck looks small next to the boat.
