SuperCrew
Driver side door wind noise
Old Jun 17, 2002 | 12:33 AM
Coumer HD F-150's Avatar
Unhappy Driver side door wind noise
My new HD F-150 has an annoying wind noise in the door. I was hoping that some of you have dealt with this issue. I only have 1,400 miles on the truck and this noise is not really something I was expecting on a new $$$$ truck. I will be taking it into the dealer next week and was hoping that you may have some heads up for me.
Old Jun 17, 2002 | 07:57 PM
10TH_ANNIV_T2's Avatar
Well, I had my 2000 Scab passenger door get caught in the wind (pulled my wife right out too!) and it bounced against the stop. Bent the A pillar & door hinge slightly. After that I saw that the leading edge of the door was slightly out from the trailing edge of the front fender. Check that. If not, it might just be that the door needs to be adjusted slightly so that the seal makes solid contact all the way around the door.
Greg O.
Old Jun 18, 2002 | 11:21 AM
ganiman's Avatar
Hey Coumer,
I had the same problem,sounded like the rear driver door was open on the highway.Took it to the dealer and they re-aligned the door and replaced the weatherstrip.Fixed it right up.
Frank
