Took some more pics of my truck
Took some more pics over the last couple of days. I know that theres a bunch of the same thing, but i couldnt decide which ones were the best, so i just left them all there on the album. Most of them were taken with my Sony mavica FD88, but a few were with my cousin's Fuji2800. The ones on the bottom row were taken when i first got the truck with a Sony mavica FD73 ( only a 640x480 resolution)
http://www.buildabox.net/supercrew.htm
Jeff, awesome truck! I am going to get one very soon. Probably exactly what you have......however I am trying to find out what the changes are for 2003 and find out what it looks like. Any ideas?
Is your truck Dark Shawdow Grey? Great pictures by the way.
hi jeff u and i have same identical truck. check mine out.
https://www.f150online.com/galleries...y.cfm?gnum=394
I wonder if that climate control is compatable with my '01 Lariat. I would love to find out. I bet it would be pricey from the dealer, though. Anybody with info, as to whether or not it will work, let me know.
it wont work, theres a main instrument panel wiring harness that would be needed thats over $1000 by itself, then the heatercase, plenum, blend door actuators, control head, the plastic around the radio is different and the plastic oval on top of the dash id different, sunload sensor, in car temp sensor, aspirator tube, ...... it would cost between $3000-$4000 to do it all.
but im not saying it's totally impossible...
It's not that great of a feature, i wouldnt worry about it. When the sun is bright, even if its chilly outside, it will blow cold air on you. Weve tried to figure out the logic of it at work, and i guess just too much input emphasis is put on the sunload sensor over the outside temp and in car temp sensor. It sucks when its 60deg and sunny outside, and you can run the auto temp up to 85 and it's still blowing chilled air out the dash vents. The next bump is 90 and that is full heat out the floor. Like my service manger says, we cant redesign them, just fix whats broke. But it isnt actually broke, so i cant fix it.
