SuperCrew
Front License Plate Bracket Removal
Old Feb 16, 2002 | 10:44 AM
Shadow Trooper's Avatar
Sounds simple enough. The lower portion of the bracket is just attached via plastic clips. The upper portion is some sort of oversized metal rivot of some sort. I haven't located a nut to unbolt. Any suggestions?
Thanks in advance
Old Feb 16, 2002 | 11:43 AM
one50npump's Avatar
either drill out the rivet or take an air chisel to it.. I used the air chisel and it took all of 4 seconds to get those puppies off
Old Feb 16, 2002 | 12:05 PM
Rockpick's Avatar
Moderator &
Hey! A fellow Louisvillian.... Good luck on those brackets...
Old Feb 16, 2002 | 01:29 PM
Thanks for the replies, hey Rock
Old Feb 18, 2002 | 11:17 AM
fritoz's Avatar
I used an old, rusty steak knife and sawed the plastic tabs off inside each recess. You can't even tell there ever was a plate there, unless you were *really* hunting for it! Besides, the leftover plastic helps to fill the gaps that are left behind.
Old Feb 18, 2002 | 09:54 PM
kkirt1's Avatar
I worked on those stupid rivets for an hour... argh! After an hour I said the hell with ever putting that thing back on whacked them off with a box knife!
Old Feb 18, 2002 | 11:59 PM
ACOLEY's Avatar
LOL KKirk1,
I did exactly the same thing
Old Feb 19, 2002 | 12:12 AM
dcovell's Avatar
Not in Cali, you have to have a plate on the front and the back of the car/truck. So don't have to worry about this mod.
Old Feb 19, 2002 | 05:33 AM
Mach1's Avatar
In Texas you get a ticket, or at least a hassle!!!
Dont need that...
