Locked In, Help!
The driver's door on my screw periodically stays locked, whether I am inside or outside the truck. The other locks function normally using either the buttons in the rig or the key fob. The power to the lock isn't affected, I can hear it trying to force the dog gone door open. So the only way to get it open is to jiggle the inside door handle while rapidly clicking the power lock button on the driver's side. It's intermitten but happens at least once a day now. Any help is of course appreciated.
Al
Al
i have seen this alot. 99% of the time it's the power lock actuator. and some time's if the door latch assy. get's stiff, from poss. lack of lube or just dirty. it will take out a lock actuator. from trying to operate something that is harder to move than normal. but sound's like it's to late for lube.
I suppose I should
wait until it happens again and drive to the dealer with the thing stuck. I don't think they would know what to replace without seeing it happen first.
Too bad a problem like this doesn't show a code anywhere!
