SuperCrew
PICTURES on sites
Old Dec 30, 2001 | 10:58 AM
joeeyo's Avatar
PICTURES on sites
OK, I am VERY new to this....
How in the heck do you guys get the pics of your truck and ALL the details about it on every reply or post, it is reallly kewl AND I just got a digital camera for Christmas.
Um, if possible (VERY detailed directions for the SCREWball!!!)
Thank you VERY MUCH in advance!!!
Joey "O"
Old Dec 31, 2001 | 05:33 PM
Lightguy's Avatar
I will do my best.
First of all the description on every post part comes from having your signiture filled out. You can do this in the user cp section at the top of the page underneath the ads. Then each time you create a post or reply to one you have the option of showing your signiture at the bottom of the post.
Posting pics:
The best way to do this is to get a photo alblum here with F150 Online. You can get information on this and setup your own alblum by going to the Photo Galleries section on the menu bar to the left. Once you have pictures on in an alblum you can click on one of your pictures and then view that pictures forum codes. Each picture has a forum code, that you can then copy and paste into your post of reply which then adds the picture. If you setup the photo alblum you will understand alot better.
You may try checking out the message boards under the F150 Site heading and check out the "Questions about site" "Site Announcements" and "Comments & Suggestions" sections. Then under the Owners Connection you can go to the "Testing 1,2,3" section to see all of this work. I always used this to test the signiture, pic posts and so on. That way you dont tie up the boards w/ mistakes.
This site is really pretty easy to use once you figure a couple of things out. They have thought of everything. I think once you setup the photo alblum you will start to get the hang of it. Submitting links and things are all real simple and are options of each post or reply you make. Next time you make a post or reply take a look at the VB Code section. Thats where you can create links or whatever. You can include a link to your photo alblum in your signiture as I have done as well as a link to a web site.
Good luck, and let me know when you get sig's and alblums done so I can check them out.
HAPPY NEW YEAR!
