SuperCrew
keyless entry
Old Dec 29, 2001 | 10:32 AM
dlh4by4's Avatar
Question keyless entry
Where did you find the factory set code for the keyless entry? There is no card in the truck, nor no number under the driver's side dashboard. These are both of the place the dealership said I could find it.
Old Dec 29, 2001 | 10:36 AM
Swofford's Avatar
In the Expedition its under the driverside area right above the gas pedal on a grey box. 5 digit number, might try looking there.
Old Dec 29, 2001 | 04:44 PM
S'CrewLoose's Avatar
In my S'Crew it is on a whitish grey box, on the fire wall, drivers side, up behind the e-brake....there are a few different numbers on the box but the sticker with the largest digits is where i found mine.
Hope this helps
Ed
Old Dec 29, 2001 | 07:56 PM
Dennis's Avatar
In mine, it was stuck in the same bag with the two remotes which were stuffed into the cup holder in the dash.
Old Dec 29, 2001 | 10:37 PM
dlh4by4's Avatar
Hope this helps
Ed
Thanks. I found it there and it works!
