SuperCrew
Fender Flares
Old Dec 17, 2001 | 08:23 AM
supercrew cajun's Avatar
Question Fender Flares
LOOKING FOR FENDER FLARES FOR 2-WHEEL DRIVE SUPERCREW XLT. THE SAME STYLE FENDER FLARES LIKE ON A LARIAT SUPERCREW.
THANKS FOR THE HELP
Old Dec 19, 2001 | 12:11 PM
ironman's Avatar
For some reason this topic does not get much activity. I have posted before with not much luck, except for a few kind souls. I too am looking at flares for my 2001 SuperCrew. If you want the OEM Ford look you probably will have to go through Ford. There are other makers of flares such as EGR and Xenon. These are a little larger type flare. I am leaning towards the EGR flares. I have a post that asks anyone what they think of the "other flares". No one has responded. You might also use the search engine google.com and search under Ford f-150 SuperCrew fender flares.
Hope this helps!
Old Dec 19, 2001 | 12:19 PM
97GreenLariat's Avatar
You'll probably have to go through Ford. I have them on my truck. (Lariat). There are holes drilled in the fender that hold them on. I have aftermarked ones on trucks around here & they look descent, just not like the ford ones
Old Dec 19, 2001 | 12:44 PM
slammedscrew's Avatar
i put on a set of factory flares on my xlt screw. i ordered them from ford and they were about 250.00 painted. i removed the push in clips on the rear and installed them by using the outside mounting holes and some black adhesive like found on the back of the plastic under the door panels. the adhesive comes in a roll and sells for about 15.00 a roll and is a 3m product. the flares come painted from ford and fit like they should. just my 2cents
