Hard to start a Screw ?
Just giving you a head's up if anyone else run's into this. My truck was having a starting problem.When I would go to start it it would crank for a while before firing & would have surging at idle on a pretty frequent basis over the last week or so. So I called my trusty Ford dealer on Friday at 4:30 pm to ask about it because it seemed to be getting worse.He asked it I could bring it in on Friday eve. at about 7:30pm ( my dealer is open everynite until 11:00 pm & Saturday 8:00am -1:00 pm, pretty nice)Anyway's they found the problem & it was an IAC(idle air control) valve assembly.They replaced it & I was down the road by 9:00 pm.Just a little tid bit more the mechanic said that if the IAC valve is bad it WILL NOT show a code when put on the scope.
Just thought you might want to keep this in mind for reference.
He said it is a fairly common problem & yes it was covered under warranty.
See ya ...Mike
See ya ...Mike
Intresting, my truck has done the idle up and down about 3 times now since I got it. I give it a little gas and it's gone. But if it gets worse I guess this could be the answer. By the way where is this sensor located??? Just curious.
