Headlight Adjustment
I have noticed that my headlights seem to be dim even on high beams. I wondering if there is anyway to either get the low beams and highbeams to be on at the same time or has any one put in brighter bulbs and if so what kind. I would alos like to know if there is way to get the fog lights to say on when the high beams are on?
Redkona - not sure on the first question, but as far as the high beams plus fogs, go to this link:
https://www.f150online.com/tech/lightningfog1.html
Not only does this mod allow you to use your fogs in any position (parking, headlights, and auto), but it also eliminates the foglights turning off when high beams are on. I did this mod a while ago and have had no problems.
On a side note, what is the significance of the name "redkona". Just wondering - my friend has a 1971 Kona jet boat that is pretty rare and I was just wondering if your signon name had anything to do with a Kona boat.
Yes there are brite boxes--which allow to run both high and low beams on at the same time...
I put 80/100w Xenon bilbs in mine--off of ebay for $15...
get the light blue tint ones...highly recomended....
Mach1 - have you not had any problems with these high output bulbs melting anything?? Someone else posted earlier that his bulbs of the same wattage ended up melting his wiring. And I have heard of this happening with other vehicles.
