SuperCrew
Spots On Instrument Clear Plastic
Old Aug 29, 2001 | 09:52 PM
DANSCREW's Avatar
I WAS SPRAYING LEATHER CLEANER ON THE MIDDLE OF THE STEERING WHEEL AND A LITTLE OVER SPRAY ENDED UP ON THE CLEAR PLASTIC. COVERING THE SPEEDO IS THERE ANY WAY TO REMOVE THE SPOTS. WINDEX DON'T WORK ANY IDEAS OR DO I NEED A NEW CLEAR PLASTIC COVER THANKS FOR THE HELP DAN
Old Aug 31, 2001 | 01:39 PM
CBechtel's Avatar
You might try some Meguiar's Plastic Cleaner or Polish (two different products). Pep Boys has sold these products. Before doing that, I'd suggest that you purchase a small bottle of eyeglass cleaner (the type which is safe for plastic lenses). This might remove the stains. If that does not work, a new plastic cover for your instrument panel should not be that expensive at your local Ford dealer. It's something you should be able to replace on your own.
