SuperCrew
turbulence in gas pedal
Old Aug 29, 2001 | 12:29 PM
Dover's Avatar
Question turbulence in gas pedal
What's up with the vibration in the gas pedal when accelerating, I would think it should be smooth. Maybe I'm just being too picky.
Old Aug 29, 2001 | 02:32 PM
TroyK's Avatar
did you adjust the pedal to see if that makes a difference. mine doesn't give off any vibrations...
Old Aug 29, 2001 | 11:16 PM
DAVEMAN's Avatar
Hello Dover,
I am not sure but I think the pedal is connected to the engine through a cable. If the pedal is transmitting vibrations then the shaking is most likey comming through the cable which implies a shaky engine. If that is right then maybe there is a loose engine mount or possibly a defective engine mount? I would think it must be something along these lines but then again it's been a long time since I turned wrenches for a living and controls and mountings may be different.
That may be wrong but it's for free.
DaveMan
