SuperCrew
4.6 Tire smoking??????
Old Aug 1, 2001 | 03:46 PM
sgeysbek's Avatar
Question 4.6 Tire smoking??????
Can anyone with a 4.6L 4X2 get there rear end to break free and spin there tires going straight??
I can get mine to do it around a corner or in gravel but not stright?
Also I have a howling or sucking like noise comming from the motor under WOT, anybody else have this?? and is it a problem or just the motor??
thanks in advance
Old Aug 1, 2001 | 04:10 PM
Mach1's Avatar
Right off idle mine will chirp the tires ...I do it often not trying to...
Here's the difference--you have the LS(?)
I live in gravel and it lights them up every time(1 wheel)..
It will not burn the thread off....
Something about throttle response is touchy off idle...
Old Aug 1, 2001 | 06:51 PM
TroyK's Avatar
Re: 4.6 Tire smoking??????
Originally posted by sgeysbek
Can anyone with a 4.6L 4X2 get there rear end to break free and spin there tires going straight?? I can get mine to do it around a corner or in gravel but not stright? Also I have a howling or sucking like noise comming from the motor under WOT, anybody else have this?? and is it a problem or just the motor??
thanks in advance
the only noise i've noticed with my s-crew under wot is that when the tranny upshifts it emits an audible "squeak" like noise. it only does this under wot and i only hear it when i have my window down. guess its those electronic solenoids trying to go about their business as fast as they can...!
