ashtray/cup holder removal
My indash ashtray /cup holder on my 01 150 has lost the spring to push it out. I pried it open and found spring in dash. my question is does anyone know how to remove the sliding tray so i can replace the spring. Looks like it may have been on two plastic pins on the back of tray.
there is a lock in the center of the top of it, you can either wedge something from the top side in there, like a screw driver, or reach up behind it with a finger and pull the lock tab down.
if you can retrieve the spring from the dash, you can put it back on using very short self tapping screws
I know it's alittle late, but the small plastic rivits if that what you call them broke on mine. So i just drilled two pilot holes and use some self tapping screws and bingo it's working again like Patman03SprCrw said !!
