SuperCrew
4.6 and 4.10s
Old Jul 14, 2010 | 09:22 AM
cleancrew's Avatar
4.6 and 4.10s
has anyone out there put 4.10s in a 2wd screw? i am thinking about it from the little motor being underpowered. last weekend i got 20 mpg on a 200 mile trip with 209k on the odometer. it currently has 3.55s and runs at about 1900 at 70. or would 3.73s be better which was my original plan?
Old Oct 18, 2010 | 10:53 AM
rocsorcs's Avatar
I can tell you that when I put 4.10's in my '01 Scab (w/4.6L & 3.55's) the standing start accelleration was dramatically increased. It did, however, turn alot of rpm's on the road, which I was knew was coming, and thought I would be okay with. I wasn't. (I wish I would have stayed with the 3.73's, which was my first gear change!) You will probably not notice a big difference going from 3.55 to 3.73 considering this is a just a ".18" increase in gearing, but your fuel economy won't change much at all. I saw between 16.5 - 19 mpg with the 3.55's, 16 - 18 mpg with the 3.73's, and 13.5 - 16 mpg with the 4.10's. All of this is on 87 octane.
I tend to be somewhat O.C.D when it comes to stuff like this, and I had
3.55's, 3.73's, and finally 4.10's in the same truck, all within a month of the first gear change. So here you go...
3.55 gear ratio:
55 mph = 1,550 rpm's
65 mph = 1,800 rpm's
73 mph = 2,000 rpm's
80 mph = 2,200 rpm's
3.73 gear ratio:
55 mph = 1,650 rpm's
65 mph = 1,950 rpm's
73 mph = 2,150 rpm's
80 mph = 2,375 rpm's
4.10 gear ratio:
55 mph = 1,850 rpm's
65 mph = 2,100 rpm's
73 mph = 2,350 rpm's
80 mph = 2,600 rpm's
Hope this helps.
Old Oct 18, 2010 | 04:32 PM
Veteran: Army
you probably got better mileage with the 4.10's
