SuperCrew
quality lowering kit
Old May 5, 2010 | 01:41 AM
cleancrew's Avatar
im looking at lowering my supercrew 3/4 and dont want it to ride real rough. do the front springs make the geometry in the front way off? which is the best way to go about lowering it? thanks
Old May 5, 2010 | 06:59 AM
FATHERFORD's Avatar
I'm a fan of the front DJM setup, but I dislike their flip kit for the rear.
Old May 7, 2010 | 09:53 AM
cleancrew's Avatar
how do 3 inch drop springs ride in the front?
Old May 8, 2010 | 12:54 AM
c_ulater's Avatar
I've been very happy with my Belltech 3/4 drop kit.
It improved my ride by softening the rear and the front coils with shocks took the extra bounce out it use to have.
I have a bad back so a comfortable ride is important to me.
Old May 8, 2010 | 01:06 AM
Ground Force 2/4 drop here with Eibach dampers. Nice handling setup.
Old May 8, 2010 | 08:37 AM
cleancrew's Avatar
what kind of shocks did you use? the ones you can get that come with the kit? does it make it hard to align with the geometry? thanks
Old May 8, 2010 | 12:25 PM
c_ulater's Avatar
Nitro shocks that come with kit.
Old May 14, 2010 | 12:06 AM
cleancrew's Avatar
what kind of angle does the 3 inch springs put the a arms in? wear out ball joints faster?
Old May 14, 2010 | 12:16 AM
get a quality progressive spring rate like Eibach.
I just went from 3/5 to 5/7 drop
Old May 15, 2010 | 08:08 AM
cleancrew's Avatar
will just control arms drop it in the front with stock springs? do the 3 inch springs put much of a strain on ball joints?
Old May 18, 2010 | 12:02 PM
yes and not too bad on the BJ's my uppers lasted 50k lowered 30 non lowered, my lowers were done at 60k, so 30 lowered, 30 non lowered.
yes arms will drop 2" and keep factory ride quality, just make sure you get UCAs to turn the ball joint at the correct angle for being lowered.
Old May 18, 2010 | 06:02 PM
cleancrew's Avatar
right now my truck has 207xxx and still has all factory ball joints and tie rod ends and is all tight. i took off my lightning wheels so they wouldnt wear them out as fast. where is a good place to get the lower control arms? whats uca?
