SuperCrew
Auto Locking Doors
Old Jun 13, 2001 | 07:06 PM
whitengray's Avatar
Post Auto Locking Doors
I have been trying to disable the auto locking door feature, a real pain, my .02 cents. The manual lists two ways to do it, niether has worked. Has anyone out there done it sucessfully?
2001 Lariat Screw. Gen.3,
5.4, 4x4, All white w/ gray interior. 4r70w tranny, no problems yet,
wrong radiator, 3.55 gears
Old Jun 13, 2001 | 07:20 PM
ScrewKing's Avatar
Post
Yes
Old Jun 13, 2001 | 10:56 PM
whitengray's Avatar
Post
Did you use the key method or the keypad on the door?
Old Jun 13, 2001 | 11:04 PM
tfratzke's Avatar
Thumbs up
I used the key method and i got it to work the first time. Make sureyou read the directions carefully, it's a little tricky.
Tony
'01 SCrew 4x4 XLT 5.4L
Old Jun 14, 2001 | 08:40 AM
LightningCrew's Avatar
Post
I was able to do this with the keypad. Was fairly simple - just followed the directions. The only thing - you must have the little card that has the original factory settings for the keypad and punch in that 5 digit code. If you put in your own personal code that unlocks the doors - that won't work. If I remember correctly, if you do the process right, the horn will honk at you.
2001 Supercrew Loaded
Oxford White
Lightning Front End and Wheels
Supercharger to come!!
Old Jun 15, 2001 | 08:20 PM
whitengray's Avatar
Thumbs up
Got it! used the key method. Thanks for all your posts.
5.4, 4x4, All white w/ gray interior. 4r70w tranny, Jingling noise in front drivers side,
wrong radiator, 3.55 open gears.
