? for those with 37/38s
k i gotta 6" fab and i have a 3" pa body imma put on after i save up for gears and tires but i was curious do yall have any clearance issues with your tires like rubbing or yall have to buy spacers??
Mine is just leveled and I ran 37's. I did have to trim a little bit of the plastic on the bottom of the bumper and used a 1/4" spacer to keep from rubbing the frame because of the factory wheels. I believe with 9 inches you'll be fine.
Definitely going to have to trim the front plastic valence a little. Depending on the width of the tires/backspacing of the wheels, you may need to trim the tabs on the lower control arm.
