SuperCrew
ford bedliner doesn't fit
Old Mar 12, 2001 | 05:49 PM
barngoddess's Avatar
Question ford bedliner doesn't fit
The sides of my bedliner are starting to pop out from under the railings. Anyone else have this problem, and any suggestions. I remember reading that there were types of bedliners, the first being short and defective - couldn't find the link. Thanks.
Old Mar 12, 2001 | 08:38 PM
dspit's Avatar
Unhappy
I had the same problem. This is not the best remedy, but I heated the sides wuth a heat gun to get them movable and forced them back under. Then a little Super Glue sealed the deal. Best bet, see if the dealer will pull it and refund, because out of the hand full I have seen with factory bedliner, they all have the same problem. I'm saving out for a spray-on liner.
Old Mar 12, 2001 | 09:10 PM
FedExPilot's Avatar
Post
Barngoddess;
The BEST remedy is to take it back to the dealer. Here is a note from the thread listed below.... sound familiar ??? Duraliner, who makes the ford OEM bed inserts, didn't get it right initially, and made the sides about a 1/4 inch too short. Sounds like you got one of those ??!! See the thread ... BOL
August 6, 2000: "I installed the Ford/ Duraliner a few days after I picked up my Super Crew.It appeared to fit (just barely) under the rails. Since then, it has pulled away from the rails above the wheels. Photos are attached. I'm a little reluctant to drill holes and screw it into the bed. I suppose stainless steel screws with a little silicone would close the gap (see picture). Wonder if there is another "fix".How did the dealership attach the liner sides?"
The "fix" was taking it back for a correctly manufactured liner .... see the thread below...
https://www.f150online.com/f150board...ML/000391.html
<A HREF="http://albums.photopoint.com/j/View?u=1023393&a=8790857&p=28542295&Sequence=1" TARGET=_blank> </A> <A HREF="http://albums.photopoint.com/j/View?u=1023393&a=8790857&p=28542675&Sequence=2" TARGET=_blank> </A>
2001 F-150 Super Crew Lariat 4x4
5.4 engine; Chestnut w/ gold trim; Captain's Chairs; Ford/ Duraliner bed insert; Access Tonneau bed cover; Six disc CD changer in '98/'99 Expy center console; Fosgate FNP1614 component speakers (front); Pioneer TS-A6855 speakers (rear); 8 inch MTX sub in custom built, center console, sealed enclosure; ZAPCO AG150 amplifier; DRL daytime running lights; Moon roof; Bed extender; Class 3 trailer hitch
[This message has been edited by FedExPilot (edited 03-12-2001).]
Old Mar 12, 2001 | 09:58 PM
BIG EAGLE's Avatar
Exclamation
If the bedliner does not fit properly take it back and have it replaced. The parts will be replaced just like nay other defect. Good luck I haave now had my second one for 7 months.
Old Mar 13, 2001 | 03:05 PM
tfratzke's Avatar
Wink
I am glad i saw this! I noticed this problem of it not fitting under the rail and was wondering if thatwas how it was suppose to be or if something was wrong! I have to go back to the dealer for a new piece of molding that was defective anyway, so i'll bring the bed liner to their attention also!
Tony
'01 SCrew 4x4 XLT 5.4L
