SuperCrew
Antenna
Old Mar 13, 2001 | 09:31 AM
jnb412's Avatar
Post Antenna
I am looking at a SuperCrew Lariat and the Antenna hits my garage when I pull in. The dealer does not seem to keen on helping me swap it out (These trucks sell themselves).
My questions is, How do I swap it out with a shorter one? Can I just screw it on and keep the same reception?
Thanks in advance,
Joe
Old Mar 13, 2001 | 11:17 AM
rasch's Avatar
Smile
I think probably everyone who owns a S'Crew and has a garage hits the antenna on the opening on the way (unless you park in an airplane hangar). Mine only hits the top 3-4 inches of the antenna so I didn't worry about it. A figured as long as I don't tear in or out of the garage, I won't have a problem, and since it is a tight fit for the S'Crew to begin with, you don't have to worry about me tearing in and out of the garage. I take it nice and easy!
I know I didn't answer your question, but if it is only hitting the top little bit of the antenna and only on the way in and out of the garage, I wouldn't worry about it.
2001 F-150 S'Crew
Lariat 4x4
Oxford White w/ silver accent (two-tone)
5.4L V-8
skid plates
rear-slip
graphite leather (60/40 bench)
Husky liners
Jason Dimension tonneau cover w/ skid mat in the bed
Old Mar 13, 2001 | 11:20 AM
jnb412's Avatar
Question
Thanks...But the Antenna just whips like a mother and I'm afraid I would break it. I'd just as soon replace it.
Any others with info would be helpful.
Thanks,
Joe
Old Mar 13, 2001 | 11:21 AM
CACeeJay's Avatar
Talking
I bought one of the short flexible antennas from Pep Boys (~ 1 ft long). It came with a set of threaded inserts that allow it to mounted on a variety of bases. One of the inserts worked perfectly with the SuperCrew base. I haven't noticed any degredation in reception...but then again, I live in the city.
XLT 4x2 5.4L 3.55L/S CapChairs 6CDChgr BedExtender Moonroof 2Tone-IsBlue/Silver SmittyBilt Nerf Bars-Black Stull Billet Grille TopDeck lid Ford bug deflector Duraliner Air Force One FIPK Gibson Sweptside SI/SO
Old Mar 13, 2001 | 11:38 AM
Airial's Avatar
Post
You could clip a few inches of the antenna,
put the little black tip back on.
Radio works fine & antenna looks fine.
If you do a search on 'Antenna' you will
find a detailed description on cutting the antenna. I used that and my radio works fine.
Airial
Old Mar 13, 2001 | 11:44 AM
Airial's Avatar
Post
CPAFAY posted this ~ it worked for me.
For the antenna problem, I pulled off the black ball on top with pliers, clipped of a couple of inches with side cutters, filed, stuck the ball back on, and touched up with some black spray paint. Good as new.
Old Mar 14, 2001 | 12:10 AM
ryjohnson18's Avatar
Exclamation
jnb412
I had the same problem with my antenna when I got my truck lifted the standard antenna is 32 inches. I went to the local truck store and got an 18 inch antenna for around $10. To install it all you need to do is use a wrench and unscrew the factory antenna. Be sure to wrap a towel or something soft around the wrench so you don't scratch it. Just repeat the process when you put the new antenna on. It takes all of about 2 minutes and it has not affected my reception.
2000 F150
4x4 off road package
5" Superlift
Magnaflow True Dual Exhaust
Westen Polished Nerf Bars
Alphine Stero System
Cale Induction Hood w/ Cobra Intakes
K&N Air Intake System
