SuperCrew
Buzzing Gas Pedal!
Old Feb 17, 2001 | 12:11 AM
skydiver's Avatar
Question Buzzing Gas Pedal!
Does anyone else have this problem!!?? I just bought a 2001 SCrew. When I am accelerating away from a stop light, between 1,200 and about 2,000 RPM, the gas pedal vibrates/buzzes. The vibration is more noticable at between 1,200 and 1,500 RPM, especially when you start to let off the gas, then ease back on again. At first I didn't notice it, but after a while, especially in stop and go traffic, it is annoying. My SCrew is a white 2001 F-150 XLT 4X4 with the off-road package. It has the 5.4 L engine, 3.55 L/S rear-end, 17 wheels and tires. Has anyone else had this problem? If so what was the cause, and did you get it fixed? My truck only has 1,200 miles on it, and I really enjoy driving it, but these type of vibrations belong on a cheap motel vibrating bed, not my truck!!
Old Feb 17, 2001 | 09:54 AM
JimWright's Avatar
Post
Mine does this sometimes too... thought it might be normal... if anyone can confirm that their pedal never buzzes, I'll tell the dealer about this when I go in to have them look at the tranny & differential next week...
-- Jim
Old Feb 17, 2001 | 01:18 PM
2000 F150 4x4's Avatar
Post
I got the same thing with the passenger door. It's the air pressure. If you leave your door open while they close theirs it will work much better. As the seals wear, it will be less noticeable.
2000 F150 XLT 4x4 Short Bed. Amazon Green, 5.4L, SuperCab, ORP, Tow Package, Sliding Rear Window, Electronic Shift, Keyless Entry, LT265-70-17 Tires, Clarion Pro Audio, Herculiner Bedliner, Air Silencer Removed.
1994 SVT Mustang Cobra. #1032 of 6009. Black coupe with black leather int., 3.73 rear, Bassani Exhaust, Aluminum D/S, Bridgestone RE-71 255-45-ZR17
My Home Page
Old Feb 17, 2001 | 01:23 PM
1BADF150's Avatar
Post
mY 5.4 REG CAB FLARESIDE DOES IT TOO,...AS SOON AS I CHANGE MY OIL ITS GONE...I DONT NO WHY MAYBE ITS JUST COINCIDENCE BUT WHEN I NEED AN OIL CHANGE OR BEFORE IT WARMS UP ON AN EXTREMEMLY COLD MORNING ITS ALWAYS DONE THAT SO I WOULD JUST TRY AN OIL CHANGE..ITS A CHEAP FIX
Old Feb 18, 2001 | 12:58 AM
zacky's Avatar
Talking
No Vibration`s here gas peddle is about mid postion
only problem i have is seems everyone has to shut passanger side door twice before its completely shut any other have stiff passager side door ? cold here
Ordered 11/8/00
Build Date 11/27/00
Delivery Date 1/06/01
XLT 2001 Supercrew
Arizona Beige
5.4
Tow Pk
Captain chairs
Ford Duraliner.
Stull Billet Grill
Nothen` Dirty` Going` On`Here`
Old Feb 18, 2001 | 09:09 PM
MOD2FLY's Avatar
Post
Both peddles vibrate (I have 1000 miles on)
but only when WOT and getting over 3000RPM.
It is probably a result of having the
adjustable peddles to begin with.
Any other thoughts on this??
Todays Quote:
*I am not Pissed off, I just drive that way*
The best of both worlds
2001 Corvette/2001 SCREW
*Laura*
[This message has been edited by MOD2FLY (edited 02-20-2001).]
Old Feb 19, 2001 | 07:36 AM
Supercrew-Rick's Avatar
Unhappy
Hello Gang,
Mine too. Gas pedal starts vibrating only when accelerating and de-accelerating. Brake is fine.
It makes my foot tingle (go to sleep) after a while. It sux.
I purchased my maxed out Lariat in September.
Took it back to the dealer. Service couldn't find anything (go figure).
I took my salesman for a ride in another Screw to prove it to him. He finally notice it.
"Long story short". Since they had no clue, they had no suggestions!
I posted it here immediately and no one responded.
' Thought I was was just too ****.
I put a Dr. Scholls insole pad on the gas pedal. Helped some, not much.
Maybe I'll try a another brand!
I have 8300 miles on it and still haven't been able to ignore it, but the truck is awsome.
Later dudes!
Old Feb 19, 2001 | 11:41 AM
DECHman's Avatar
Post
Happened a couple times to my wife and I, not all the time though!
~DECHman
2001 S-Crew Lariat, 2wd, 5.4L, loaded, astro tonneau cover, bedrug, dealer installed bug gaurd, Precsion Power PC 2300 LE 300W amp, 2x JL Audio 8w3d4 subwoofers under rear seat, Clifford alarm with remote start, tilt, prox, omni sensor, window control, radio control, headlight control, back up battery siren, window tint, PIAA 9007 SuperWhite headlight bulbs with CATZ Zeta headlight enhancement transformers.. soon to have new subbox with a JL Audio 10w6 woofer.
Daily ride.. 1987 DECH Mustang 5L Hatchback with way more mods!
dechman@yahoo.com
Old Feb 21, 2001 | 12:47 AM
skydiver's Avatar
Post
Supercrew Rick and everyone else,
Thanks for taking the time to reply about my buzzing gas pedal problem. Thought I was being a bit **** as well!! I will be taking truck to the dealer before the first 5,000 mile service is due because of a pull to the left I want to get fixed before the tires start to wear uneven (I also want to get the tires reversed so the black walls are facing outward. I will see what they have to say and post it if I get a decent answer. Like MOD2FLY, I also get a heavier buzzing when I really get into it, above 3,500 RPM. I plan on leaving my posting for a while. Maybe someone else will see it and reply.
Looking forward to really trying out the 4-wheel drive in the next couple of weeks!!
Thanks again,
skydiver
Old Feb 21, 2001 | 08:01 AM
ExpyBob's Avatar
Post
On the Expy there was a TSB to reroute the accelerator cable. They unfastened it from the power steering resivoir and insulated it.
I had it done to my 99 Expy and it worked. The 2000 didn't need it---Bob
The vehicle above is one of many. Try refreshing. It goes by random but the Expy was exactly like mine. Now it's a
2000 EB Expedition 5.4L, Estate Green with all the perks,3.55 LS,Heated and Signal Mirrors and Seats Moon Roof. Auto adjusting peddles,seats, and mirrors. Rhino Step Bar (coming), Ford Bug Shield,Even the hitch propeller, More to come... My 99 Expy was destroyed in a Wisconsin Tornado (No B.S.) Allstate did good by me but I still took a hit on mileage.
Old Feb 21, 2001 | 08:02 AM
arbee's Avatar
Post
Haven't noticed the gas pedal vibration but I will check. Hopefully it's not there or it will drive me crazy now that it has been pointed out .
I definately see a big difference in the passenger door. You have to close it HARD but the driver's door is nice. I don't think it has to do with air pressure though as I have tried them independently.
Has anyone noticed a whistling from the passenger door area that almost sounds like a spark knock? Seems to be most prominent during a cross wind.
2001 Supercrew, 4x2 XLT
4.6, Arizona Beige with Deep Wedgewood Blue Accent
Options: CD Changer, LS Diff, Towing Package, 2 tone paint, 47F appearance package, 5 spoke cast wheels
New seats with front and rear adj. head rests
Built ~11/04/2000
Future Mods: hard tonneau, spray in liner
Old Feb 21, 2001 | 09:02 PM
Parktek's Avatar
Post
Guess I'm one of the lucky ones; haven't had any problems with the pedals or doors. Actually, I haven't had problems of any kind yet other than the "orange-peel" in the paint around the tail lamps that some others have posted about...........
2001 F150 4X2 XLT Supercrew, D.Wedgewood Blue, 5.4, 3.55LS,
Class III, Cargo Cage, etc....
Old Feb 22, 2001 | 12:33 AM
JERSEY FRESH's Avatar
Post
I TO HAVE FELT THE VIBES. GOT MY SCREW IN
SEPTEMBER. DOES'NT DO IT THAT MUCH BUT IS
VERY ANNOYING. NOW THAT ENOUGH OTHER PEOPLE
HAVE THE SAME PROBLEM, MAYBE WE'LL GET AN ANSWER. KEEP POSTIN PEOPLE. I LEARN AN AWFUL
LOT FROM THIS BOARD. THANX. BRUCE
Old Nov 11, 2001 | 10:00 AM
ricor's Avatar
Post Gas pedal vibration!!
I had the same problem until 2 days ago. After numerous visits to the dealer, one tech finally got it.
The accelerator cable is quite short and distorted (S-shape).
It is also mounted in bracket mounted on the manifold.
He unclenched it from the little holder that keep it in place and let the cable stand freely without being in the bracket.....Well LO-AND-BEHOLD---the vibration is totally gone.
I hope this helps all of you, it sure put my mind at ease..
Ricor
