SuperCrew
Tire size with body lift??
Old Nov 7, 2000 | 03:13 AM
VeryBlueScrew's Avatar
Question Tire size with body lift??
Does anyone want to take a guess at what size tires could fit on a Supercrew with 16 inch rims and a 2 inch body lift in the front and a 1 inch body lift in the back? The front is a inch lower then the back is stock. I have been told you can fit 315's without a body lift or suspension lift.
VeryBlueScrew
Old Nov 7, 2000 | 05:01 AM
F-trucks's Avatar
Talking
First of all you didnt say if it is 2 or 4 wheel drive if it is 4 wheel drive without body or suspension lift i know you will have no trouble at all with rubbing with the 285/75/16 on 16 + 10 inch rims not sure on the 315"s though? when you put a body lift on it raises the front and back the same height they are spacers that go between the body cab and bed mounts and frame! if you go with a 2 inch body lift it will leave a big very ugly gap in the rear top bumper and lower tailgate cause the 2 inch body lift doesnt come with rear bumper raising brackets if i was you go with the 3 inch body lift it has the front and rear bumper raising brackets so it will look like factory i went with performance accesories body lift also get the lift lips to go in the fenderwells to hide everything here is a few pics of mine with 3 inch body lift 16+10 rims www.ftrucks.homestead.com
