SuperCrew
Differential
Old Oct 27, 2000 | 07:20 PM
w/s SCrew's Avatar
Question Differential
I ordered my Screw without the Limited Slip, What are your your opinions on this item as a necessity? I have a small boat(1400#) to pull. Thanks
Old Oct 27, 2000 | 10:20 PM
crewchief's Avatar
Post
I never gave it a lot of attention untill one rainy day when I found myself in an intersection with another car aproaching from the right. He was locked up and sliding as he approached, I think he forgot about the stop sign. Now I think that he would have stopped before he hit me but nonetheless I punched the accelerator. I could actually feel both rear tires hooking up and pushing me out of the intersection! I was supprised especially since I've got those crappy GoodYear RT/S tires. When I stomped on it they started spinning but equally and had me going in a straight line. It never got squirrely and I felt very in control of the truck.
Thats my notable experience with the LS rearend so far, maybe someone else could give you more "hard/technical" info. -wayne
2001 Supercrew XLT 4x4.
Superchipped 5.4L, 3:55ls, tow package, heavy-duty electrical and cooling, skid plates, 17" 10 spoke wheels, remote keyless entry, cabin air-filtration kit, moonroof, bed extender, "Ford" rubber bed mat, rear slider, dark graphite int. and bright red exterior, SnugLid hard tonneau.
mysupercrew.com
Old Oct 28, 2000 | 01:54 AM
Screwit's Avatar
Post
1400 lb is not a lot for the crew but limited slip is a nice thing on a wet ramp.
You did not say if it was 4x4 if so don't sweet it you well have the fronts on dry land.
I pull a 4000lb boat no sweet in 4x2 and don't use 4x4 mode but it sure is nice to know it's there.
2001 SUPER CREW 4x4 Lariat White,Graphite Leather captain's chairs, 5.4L,Moonroof,6CD,limited slip,Tow and Off Road package, Bed Extender, Bug Guard, K&N, Magnaflow 3",Line-X Beadliner,Snug Lid,CRL Powerlite rear window
Old Oct 28, 2000 | 10:44 PM
Rivers's Avatar
Smile
I guess you'll get a lot of different opinions on this one...Mine would be if you have a 4x4, I don't see the need for a slip.
rear end..The way I look at it, if your spinning out on one side, you kick in your 4x4 and your out of there. That's my opinion and that's why I didn't order my SuperCrew with a slip-rear end...
2001 F150 SuperCrew Lariat 4x4-4.6 V8-508A Lariat package-Dark Hiland Green-Leather Captains Chairs-P/U Bed Extender-Rear Sliding Window-Skid plates package-Cab.Steps-Lower twotone paint-Power drivers seat/autolamp-Engine block heater-17" Chrome Wheels-Bed Liner
Old Oct 28, 2000 | 10:55 PM
anteater's Avatar
Question
You didn't say if you have a 4x2 or a 4x4 coming? In La. you probably wouldn't need the LS all that often on either drive system. But, if you pull your boat too far down the ramp... you may not get out without it. Up here in the northern areas, we use posi for snow traction, with a 4x2 I think it's vital!
2001 Screw XLT
Oxford White, 5.4L,
Towing, Posi, Slider
Power seat, keyless
bedliner
Old Oct 28, 2000 | 11:21 PM
KB's Avatar
KB
Cool
Basically, I agree with the other opinions here. Limited slip diffs are always great when pulling your boat off the boat ramp expecially if the ramps are not always maintained. Grass, moss, seaweed will help you lose that much needed traction. It's fun to watch those 4x2's without LS screeching their vehicles out of the water.
2001 S'Crew Lariat 4.6L, Black / Harvest Gold trim, running boards, Gibson SS Exhaust, bed rug, tow pkg., lim. slip, 6 cd
Old Oct 29, 2000 | 12:22 AM
Truckdog's Avatar
Unhappy
On the topic of differentials: In another post cpafay mentioned that his differential was leaking. I have the limited slip and noticed that mine is also leaking out the front end. I plan on taking it to the dealer soon. Is anybody else seeing any leaking out of their differentials?
'01 Lariat Supercrew Oxford white, 4X4, 5.4 V8, limited slip, skid plates, tow package, captains chairs, Line-X, Super-Whites bulbs, Westin Nerf bars, Snugtop XV, Husky floor liners.
Old Oct 29, 2000 | 11:12 AM
mjhind's Avatar
Cool
Even with a 4x4 the LS is nice to have. The post above about getting out of the way of a wreck wouldnt have been the same if he wuould have had to switch to 4x to get out of the way. I like the LS when I'm in 2x.
2001 Supercrew XLT 4x4, 5.4, tow pkg, limited slip, skid plates, 6 disk, keyless entry. Deepwedgewood blue ext. Dark graphite int.
Mods: full tint, westin chrome nerf bars, AR chrome sliders 16x8 and BFG AT 285/75
Old Oct 29, 2000 | 06:14 PM
JMTruck's Avatar
Post
And we have to consider that the tires must not be slipping when changing from 2x4 to 4x4.
1998 F150 4x4 Lariat Supercab Flareside 5.4L in Oxford White/gold, ORP, Tow Package, 3.55 Gears.
Modifications: K&N FIPK, Stepshield door sill protectors, Performance Accesories 3" body lift, Lift Lips and Daystar front anti-sway bar polyurethane bushings.
See photos at http://www.communicomgroup.com/jmtruck
Old Oct 30, 2000 | 04:24 AM
1 Illinois SCrew's Avatar
Post
I ordered mine with limited slip. Without limited slip, if you get into a situation where one front tire and one rear tire both lose traction, you can get stuck since power is sent to the tire with the least amount of resistance. Even with four wheel drive and limited slip, there are times you may get stuck. The limited slip just reduces the chances of that happening since it will send power to both rear tires even when one has already lost traction. It's a $243.00 (dealer invoice) insurance policy against having to get pulled out! I think it's pretty reasonable in the long run.
On Order 10/18/00:
2001 Arizona Beige XLT SCrew, 4X4, 5.4L, Limited Slip, Captains Chairs, PWR Driver Seat & Automatic Headlights, Sliding Rear Window, Class III Towing, Off Road Package (HD Shocks, Off Road 4X4 Decals, Skid Plates, P265/70R17 all-terrain OWL tires, 17" 10-Spoke Cast Aluminum Wheels)
Old Oct 30, 2000 | 10:43 AM
minncrew's Avatar
Angry
Truckdog,
My diff. is also leaking from the front. Not a big leak more like weeping. Just a little wet but not dripping.
2001 SuperCrew XLT 4x4, 5.4L, 3.55L/S,
Rear Slider, Skid Plates, Keyless Entry,
Tow Package, Cab Steps, Black, Line-x
Bedliner, Raven Topper
