SuperCrew
Transmission shifting hard
Old Sep 18, 2000 | 06:11 PM
B Clark's Avatar
Post Transmission shifting hard
I posted this in the transmission forum but also wanted to check with ya'll. I have a Supercrew that is 2 weeks old and every once in a while the tranny shifts with a heavy jerk. I found that by using the cruise it will do it every time. When I cruise at 75 and hit the brake to slow to about 65 when I hit resume it shifts down to 3rd until it gets back up to 75. When it gets there it shifts back into O.D. with a really hard jerk or pop. Before I take it for warranty I wanted to get some insight from ya'll so I'll be better prepared for the "There's nothing wrong with it." diagnosis. Thank's for everyone great input on this board, there have been alot of answered questions simply by reading the posts.
2001 Crew white/harvest gold 5.4
auto 3.55 4x4 leather lariat
Old Sep 18, 2000 | 08:56 PM
Mtnmike's Avatar
Post
I have had my S-Crew three weeks and 600 miles. 5.4L engine. I have never experienced the problem you describe. In cruise control driving in the mountains on a highway which goes to 11,000 fett I disengaged cruise because of the constant shifting (which was to be expected under those conditions); but the shifting was never hard or real noticeable. If I were you it would be at the dealership being looked at.
Mtn Mike
Old Sep 18, 2000 | 09:36 PM
crewchief's Avatar
Post
At 9K miles now and never has our truck shifted with a hard jerk or pop as you discribe. Not even with the Superchip which firmed up the shifting over the stock programming.
2001 Supercrew XLT 4x4.
Superchipped 5.4L, 3:55ls, tow package, heavy-duty electrical and cooling, skid plates, 17" 10 spoke wheels, remote keyless entry, cabin air-filtration kit, moonroof, bed extender, "Ford" rubber bed mat, rear slider, dark graphite int. and bright red exterior, SnugLid hard tonneau.
mysupercrew.com
Old Sep 18, 2000 | 09:53 PM
Wingnut33's Avatar
Post
I have had mine 17 days and have 1,000 miles already and I am noticing the hard shift as well.
It doesn't happen often, but when it does, it's really noticeable. I'm not sure why it's happening, but I have an appointment with my dealer this weekend and I will ask them and get back to you guys.
2001 Bright Red Supercrew
4X4
5.4 V8
No Mods yet, but they're coming!
Go Bucks!
Old Sep 18, 2000 | 09:58 PM
Wingnut33's Avatar
Post
Hey Chief,
I have a question about your air filtration system. I tried your email at mysupercrew.com but it didn't work. Send me your email address if you get a chance.
Thanks,
vpaini@interactivedesign.net
4X4
5.4 V8
Go Bucks!
Old Sep 19, 2000 | 02:06 AM
crewchief's Avatar
Post
Wing,
I corrected the e-mail glitch and it should work fine now. If not wayne@hewus.com will get mail to me also. -wayne
mysupercrew.com
Old Sep 19, 2000 | 06:25 PM
crazy j's Avatar
Post
I have had my Screw for over a month and have noticed no hard shifting. Even while cruising up down steep mountain highways the transmission still shifts very smoothly (I turn OD off). The first Screw I test drove is a different story. The first Screw I had driven was an XLT with the AT and 5.4L. Most of the shifts during the test drive were relatively smooth, but every now and again the tranny would shift with a very hard jolt at around 45-50 mph. This was under normal acceleration and not the typical test drive pedal to the metal. I was skeptical about buying this vehicle because of this, but after test driving 3 more Screws without the hard shifting, I decided that the this was an isolated incedent. I would take it in to get it checked out before it becomes a big problem. Hope this helps.
F150 SCREW LARIAT 4WD -White with Harvest Gold two-tone, 5.4L, LSD, skid plates, bed extender, cd changer, rear av entertainment center, sport bucket seats, rear sliding window.
Old Sep 19, 2000 | 10:23 PM
JMTruck's Avatar
Red face
Is your Check Engine light coming on? The only time that my transmission was shifting hard was when the MAF fried out. By being damaged it start sending the wrong message and you can get neck braking hard shifts with a lot of "bangs" and "clunks" coming from the differential and the shaft.
Looks like your problem may be a different one, but I posted this just in case.
1998 F150 4x4 Lariat Supercab Flareside 5.4L in Oxford White/gold, ORP, Tow Package, 3.55 Gears.
Modifications: K&N FIPK, Stepshield door sill protectors, Performance Accesories 3" body lift and Lift Lips.
See photos at <A HREF="http://www.communicomgroup.com/jmtruck
" TARGET=_blank>www.communicomgroup.com/jmtruck
</A>
Old Sep 19, 2000 | 11:03 PM
canyonslicker's Avatar
Post
I've had mine for a couple weeks . The only times it shifts hard is when accelerating uphill and easing off the throttle .
