SuperCrew
Mud in taillight housing
Old Mar 13, 2000 | 10:22 AM
Truckdog's Avatar
Unhappy Mud in taillight housing
I took my new white supercrew out in some mud last weekend and found that the taillight housings fill with mud from the rear tires. Every time I rinsed, more dirt and gravel would come out. Has anybody found a way to cover the holes on inside of housings to keep mud out?
'01 Lariat Supercrew Oxford white, 4X4, 5.4 V8, limited slip, skip plates, tow package, captains chairs.
Old Mar 14, 2000 | 12:22 AM
wildchild's Avatar
Post
check your back up lights to see if they still work. took my truck deerhunting last year and after a couple mudholes noticed muck in the housing and oh oh no more back up lights. sorry haven't got fix yet.
Old Jun 21, 2000 | 10:17 AM
Thad's Avatar
Question
Has anyone else noticed water coming out from under the tail light lens cover? Have you found a cure? I took the lens out to have a look and it looks like something should be added to close off the direct path of water from the tires to the tail lights. I wonder if it wasn't a concern with everything being plastic?
Old Jun 21, 2000 | 01:21 PM
cpafay's Avatar
Thumbs down
The water/mud around the lights bothers me too. It just takes one trip in the rain or through a puddle and I have dirt all around my lights. Wonder if it is possible to put a bead of clear silicone on the inside to stop this? The step-sides that use these lights may not have the problem because it is not such a direct path in the fender well to the lights. (?)
'01 SuperCrew 4x4 Lariat, 5.4, Amazon Green/Gold, med parchment, Moonroof, captains, 6cd, skids, slider.
Old Jul 12, 2000 | 01:06 PM
Thad's Avatar
Post
I was at the dealer today to ask if there was a notice out on the water in the lights,,, nothing yet. They said its the first they have heard of it. Has anyone else found a cure? Either a larger mudflap or a large rubber gromet to block the holes in the bottom of the tailight?
Old Jul 12, 2000 | 05:24 PM
Truckdog's Avatar
Post
I finally decided to clean out behind the tail lights by removing them from the truck. What I found really surprised me. I expected to see a couple of small holes for the wiring harness to go through, instead I found large (several inches square) holes that looked like they were cut out with a Sawsall. When you look through these holes you can see directly to the rubber on the tire. No wonder it got so muddy inside. It is going to take a wheel well liner or a lot of duct tape to cover these holes. Has any body else pulled their tail lights to see the same thing?
Old Jul 12, 2000 | 09:48 PM
Thad's Avatar
Post
If you think those holes were big, look at the top of the housing, directly above the two on the bottom.
I put some rubber over the holes, above and below {like a sandwich] and connected them with plastic push in connectors, like those used on doorpanels. I then hung a flap just inside the one in the wheelwell. You wouldn't see it unless you were trying to find it. We'll see if it made any difference next rain.
[This message has been edited by Thad (edited 07-12-2000).]
