SuperCrew
Tire size upgrade?
Old May 27, 2000 | 05:28 AM
Setter Man's Avatar
Question Tire size upgrade?
Question: What is the largest tire size & rim width combination that can be used on a SuperCrew, WITHOUT having to do a suspension or body lift? I purposely got the base tires on 16" rims, as I intend to upgrade my factory rims/tires.
I've heard that you can go with a 33x12.50 on a 8"-10" wide rim on a F-350 SuperDuty, but that this doesn't hold true for the SuperCrew.
Anyway, any input would be appreciated!
Old May 28, 2000 | 04:18 PM
richo's Avatar
Post
You can use 285/75/16 or a 305/70/16. 16 x 8 rims are the largest you can use without a lift kit.....good luck.
2001 F150 SuperCrew Lariet, 4WD, Bright Red, Tan Leather, all options except the engine heater and overhead screen. Rancho 4 Inch Lift Kit with RS9000's Shocks, Eagle Chrome Style 149's 16x8 with BFG A/T KO's 285- 75-16's, Tinted Windows
Future Mods: 315-75-16's tires and 16x10 wheels, Line-X Bedliner, Innovation Industries Sport Wing Tonneau cover.
Old May 28, 2000 | 05:57 PM
Setter Man's Avatar
Post
Thanks, Richo! I'll look into those sizes.
I want to upgrade the tires without needing to lift the vehicle, or to lift it as little as possible. It still has to serve as a pracitcal working truck for bird dog training, fishing and hunting.
Winches and chains should take care of most off-road problems. If not, I'll just take my highly-modified Isuzu Amigo, with its short wheelbase, dual winches (front/rear), 32x11.50s and 5.555 lim. slip rear diff.
[This message has been edited by Setter Man (edited 05-28-2000).]
Old May 30, 2000 | 04:14 PM
SuperCrew's Avatar
Post
I gotta believe the 18 x 9 wheels (Lightning) will fit a (4x4) SuperCrew. Somewhere there's a post from an Expy owner with these and the 285/60-18 tires.
Old May 31, 2000 | 09:37 PM
jberwin1's Avatar
Post
I don't know how much you tow but if you do you may want to change your gears. By going to a larger size you will decrease your gearing.
jberwin
F150 4x4 XLT Supercrew 5.4 3.55LS 17"wheels medium graphite interior skid plates tow package
