Annoying Sound...A/C dripping onto Exhaust Manifold
I was wondering if any of you SuperCrew owner's are having the same annoying thing happeneing to them. It seems that the A/C drips directly onto the exhaust manifold. This if really starting to annoy me now. Everytime I get out my truck all I hear is pshhhhhh pshhhhh pshhhhhh :-(. If yall are having the same problem please respond.
[This message has been edited by riccog (edited 04-14-2000).]
I would get that fixed somehow. I've seen steam pipes here at work crack over time from condensate dripping on them. Can't say the manifold will crack, but there is undue stress there from the heating/cooling over and over.
Ahhh yes. I have been getting that same sound as well. I do not run the A/C (sorry snow birds- but its only 70 degrees in San Diego)- only run the 'panel' mode right now.
Everytime I get out and close my drivers door, I hear the Hiss coming from underneath. It cant be good for truck. Maybe they can install some type of rubber hose that extends past the heat source, kind of like what you might find in the trunk water drain of a car- never had one of them car things before though.
In any event,it is time to check out the service department and parts department of my dealer any how!
White,XLT 4x4,5.4L
White,XLT 4x4,5.4L
Because of the rainy weather I have'nt tryed my A/C yet, but I noticed our two F150 supercabs at work with the 5.4 have the same engine/A/C setup as our Supercrews and don't make any noise that Iam awhere of. Does Ford know about this???
2001 F150 SuperCrew, Lariat,4x4,5.4,Tow,Slider,6 CD,Moon Roof,60/40,Two Tone. Color:White/Silver
Have the seame problem with 2000 Lariat. Dealer said it is normal?? Everytime I stop with a/c on i hear snap, crackle, and pop. Annoying as hell. Anybody with knowledge of Ford's a/c condensate drain sytem please help.
For what it's worth, and I am no expert, the noise is to some extent the cooling down of the exhaust system. The dripping as far as I could tell, crawling under the truck with my flashlight, comes from the exposed metal fittings of the A/C sytem just where they go into the firewall. The condensed water then drops down and hits, on my 4.6L, the sheetmetal surround near the catalytic converter and then to the ground. I couldn't find a spot where the water hit the exhaust.
By the way in crawling under there I found a 4-5" long, 1 1/2" diameter black cylindrical object fastened to and parallel to the exhaust pipe just in front of the muffler. Aside from a bomb does anybody know what this is?
Enjoy your truck everybody!
[This message has been edited by docker (edited 04-15-2000).]
Docker,
This is just a guess. But the black cylinder looking thing looks just like a weight. It may be mounted there to reduce the viabration of the exhaust pipe. The weight on the pipe will help deaden viabration.
www.over.to/SuperCrew
2001 F-150 Lariat SuperCrew, Bright Red / Silver Frost, Medium Graphite Leather, 2X4, 5.4, Moonroof, 6 CD Changer, 3.55 Limited Slip, Tow package, Bright Red Lund Nose Shield, LineX bedliner, Bed Extender coming soon.
www.over.to/Supercrew
Well Pilgrims, for what it is worth, now that Spring has come to Atlanta, I now have year two of the same sound.
Seems that the condensation from some part of the A/C assembly drops onto, I guess, the exhaust system or some other warmer part of the motor.
My dealer pretty much refuses to even investigate the symptom, as it is not a "problem".
For what it's worth, my wife's 98 Continental has the same "problem".
As I own a HobbyTown USA store, I have asked my RC Car/Plane guys to help me route a hose from the affected area to bypass any areas where the water would condense and make noise.
99.5 Lightning
Build #247
PSP Chip/Filter
Bassani full system
White/normal options
Tamiya 1/10 scale Bolt
Several old trucks/cars
Thunder & Lightning
Rag Doll Cats
E-mail MOSTOYSINC@AOL.com
Kennesaw, Ga. (Atlanta)
99.5 Lightning
Build #247
PSP Chip/Filter
Bassani full system
Thunder & Lightning
Rag Doll Cats
Did anyone find out where the A/C condensate is dripping, and find a "fix" for this symptom? i noticed it right away, but a friend with a '99 4.6 Expy does not have the problem.
2001 SuperCrew, 4x4 Lariat, Blue/silver, 5.4L Captains Chairs, 3.55LS, Moon Roof, Bed Extender.(Ordered: 2/11/00, Built 4/4-4/10, Delivered: 4/29)
Mods: Ford Vinyl floor mats, Line-X sprayed-on bedliner, Better-Built SS nerf bars, K&N Air filter, EGR "SuperGuard" painted hood shield.
http://albums.photopoint.com/j/ViewP...964&p=21336187
Future Mods: SnugTop Hard Tonneau cover; Gibson SS Dual-Sport exhaust system; SuperChip; (& Maybe: SVT Lighting wheels and Michelin Pilot LTX 285.60/HR18 tires.)
