SuperCrew
Gear Ratio question
Old Apr 26, 2009 | 05:53 PM
missmypinto's Avatar
Gear Ratio question
Found the code on door, H9. What is the stock gear ratio so I can adjust my EVO.
06, SCAB Flareside, 4.6L, KN fipk, Gibson single superflow
Old Apr 26, 2009 | 05:58 PM
YOu have a 3.55 LS. Here is the list.
This should do it for you
The following lists the gear ratios on rear axles.
19 — 3.55 non-limited slip (Econoline, F-150)
18 — 3.08 non-limited slip (F-150)
17 — 3.31 non-limited slip (Econoline)
H9 — 3.55 limited slip (F-150, F-250)
B6 — 3.73 limited slip (F-150, F-250)
24 — 3.73 (Econoline)
32 — 4.10 (Econoline)
35 — 4.09 (Econoline)
34 — 3.73 (Econoline)
39 — 3.55 (Econoline)
52 — 4.10 (Econoline)
56 — 4.10 (Econoline)
81 — 4.63 (Econoline)
27 — 3.31 non-limited slip (F-250)
26 — 3.73 non-limited slip (F-250)
41 — 3.27 non-limited slip (Explorer/Mountaineer)
45 — 3.55 non-limited slip (Explorer/Mountaineer)
46 — 3.73 non-limited slip (Explorer/Mountaineer)
42 — 4.10 non-limited slip (Explorer/Mountaineer)
D1 — 3.27 limited slip (Explorer/Mountaineer)
D4 — 3.73 limited slip (Explorer/Mountaineer)
D2 — 4.10 limited slip (Explorer/Mountaineer)
84 — 3.45 non-limited slip (Ranger)
86 — 3.73 non-limited slip (Ranger)
87 — 4.10 non-limited slip (Ranger)
89 — 4.56 non-limited slip (Ranger)
F6 — 3.73 limited slip (Ranger)
F7 — 4.10 limited slip (Ranger)
92 — 3.08 non-limited slip (Ranger)
R5 — 3.55 limited slip (Ranger)
91 — 3.27 non-limited slip (Ranger)
96 — 3.73 non-limited slip (Ranger)
R6 — 3.73 limited slip (Ranger)"
Old Apr 29, 2009 | 06:38 AM
Thanks Blue!
My H9 code equates to 3.55 gear ratio. I set my EVO to the parameters you posted last time, resulting in a WHOLE NEW TRUCK! Should I increase the gear ratio for more performance or just leave it at 3.55?
Old May 11, 2009 | 05:34 PM
cstanek's Avatar
"Increase" as is physically replace the gears? Or "increase" as change the setting on the Edge?
Old May 12, 2009 | 04:37 PM
blade08gt's Avatar
does this work for '03's also or just new gens
Old May 12, 2009 | 04:41 PM
Same for many years.
