SuperCrew
tires sizes
Old Mar 21, 2009 | 09:34 PM
ALVA's Avatar
tires sizes
i have a 4x4 2002 screw with 5.4, with no lift of any type
im looking at two tires in particular
http://www.toyotires.com/tire/pattern/open-country-mt
http://www.nittotire.com/#index%2Eti...ler%2Eoverview
and going with mamba m1's 20 inch's
so my question is whats the biggest tire i could get in each type,
i would like 35-10x20, and i will be getting a lift soon after
Old Mar 21, 2009 | 10:05 PM
wandell's Avatar
I'd suggest 305/55-20's (33x12.50) on a 20x10 inch wheel with 4.5 inches of backspacing. This combo will fit your truck by just cranking up the torsion bars and trimming some plastic off the front bumpers lower valance. If you are gonna lift the truck shortly, just do everyting at once and go with a 35x12.50-20.
Old Mar 21, 2009 | 11:15 PM
ALVA's Avatar
i really am not looking for a wide tire under 12 for sure
thanks for the imput
Old Mar 23, 2009 | 07:13 AM
APT's Avatar
APT
For a 10" wide wheel, you will want more than 1" of rubber on either side to help protect it.
35" tires will not fit on those wheels on your truck without a lift. Either do it all at once, or just stick with 33" tall tires.
FWIW, your new combo will weight almost twice as much as stock. Expect to take a performance hit (acceleration, braking, fuel economy).
Old Mar 23, 2009 | 12:05 PM
wandell's Avatar
In that case, I'd suggest a set of 20x9 inch wheels with 4.5 inches of bs and a set of 285/55-20's (33x11.50).
Old Mar 25, 2009 | 07:48 PM
ALVA's Avatar
im getting a chip, cai and body lift so i should be fine with the 35's
after i looked at cousins truck im just going to get the 35-12x20 all she has is a body lift
APT i know i will get lower fuel economy but thanks for the info
know i just need a pic of a screw with a mamba m1's or mud grapplers to compare.
Old Mar 25, 2009 | 10:01 PM
wandell's Avatar
Yes, you will be fine. I have a body lift and 35x12.50's. I just have 16's instead of 20's.
Old Mar 25, 2009 | 10:52 PM
ALVA's Avatar
question, the higher the back spacing the farther the rim sits in the wheel well and vice versa
Old Mar 26, 2009 | 12:00 PM
wandell's Avatar
RIght. More bs tucks the wheel in. Less bs pushes the wheel out. Your oem wheels have 4.5 inches of bs.
Old Mar 30, 2009 | 09:30 PM
ALVA's Avatar
would a 5 3/8 or 5 3/4 of BS, work with a six inch fabtech lift
Old Mar 30, 2009 | 10:01 PM
wandell's Avatar
I'm not sure but I wouldn't want that much backspacing on an offroad style wheel for a 97-03 F-150.
Old Mar 30, 2009 | 11:40 PM
ALVA's Avatar
its the only size they have in my preferable rim size 20x9
http://www.mambawheels.com/Mamba_Whe...ba_Type_M1.htm
but hell i guess ill get the 20x10's since they look banggin with mud grapplers
Old Mar 31, 2009 | 10:42 AM
wandell's Avatar
Yeah, I'd go with the 20x10's with 4.5 inches of bs.
