any gold 2008 supercrews
I see you are having problems posting pictures.
Here you go:
1. Upload your images to your album (looks like you have that figured out).
2. Click on an image from your album and there will be two boxes below the image. Click on the box labelled BB Code, right-click with your mouse and select Copy.
3. Go to your message that you want it inserted in and right-click with your mouse and select Paste
4. If you are linking to any other picture, here is the easiest way:
- If you are using Internet Explorer, right-click and select properties, highlight the entire address with your mouse, right-click and select copy.
- If you are using Firefox, right-click and select Copy Image Location, right-click and select copy.
- Go to your message and click on this icon
When the little dialog box pops up you then paste that address into the box. It will automatically add the img tags to your image.
Here you go:
No problem. If you are copying the link already with the img tags on each end then you don't have to use the
icon. That is why you have the img tags on each side of your images that you posted.
Now you just need to upload some larger pictures.
icon. That is why you have the img tags on each side of your images that you posted.Now you just need to upload some larger pictures.
[/IMG]
