SuperCrew
Engine swap
Old Feb 11, 2009 | 11:06 PM
Justhnkn's Avatar
Engine swap
I have an 01 crew with a 4.6 that has 180K miles on it. It appears that the piston in cylinder 2 has a whole burnt in it. I have located a replacement engine and it is out of an 07 E150 van. To my knowledge the timing cover, oil pan, intake and exhaust manifolds will have to be swapped off of my old motor. Does anyone know of any reason this should not or would not work? Any info appreciated.
Old Feb 15, 2009 | 07:03 AM
Veteran: Army
with your lack of info no wonders you haven't gotten any responses
is it a 2 valve 4.6?
why would you have to swap anything?? if it's a 2 valve 4.6 it should be game on as long as the front accssories are the same (I do know that the newer 4.6's have a better intake manifold)
Old Feb 17, 2009 | 10:20 PM
Justhnkn's Avatar
The lack of information is due to a lack of knowledge. I don't know if it is a 2 valve.
Old Feb 17, 2009 | 10:24 PM
Justhnkn's Avatar
I know it is the Romeo if that tells you.
