SuperCrew
cab leaking water
Old Feb 3, 2009 | 01:19 PM
bsmith995's Avatar
cab leaking water
Hello,
I have a 02 supercrew. When it rains water runs down the handles at the A-post of the truck. Any suggestions on where it is coming in at?
Old Feb 13, 2009 | 01:14 PM
woody49705's Avatar
I as well have an 02 supercrew and have the same exact leak and it also leaks at top of windshield where it meets the headliner and it rolls down the windshield. The handle leak makes a small puddle on the catchall floormat. I did post this problem about a year back but appearently no one else had the issue.
Old Feb 15, 2009 | 10:09 PM
Pete B's Avatar
Water in Door Post
Just be thankfull it has not found it's way to the fuse panel yet. At Christmas I had to have my 01 Super Crew towed out of the way of my wifes car. Took out the starter and cleaned it up and re installed 4 hours later still no good. While I was fixing the starter I had put battery on charger. When I hooked it up I found the heater was running even though turned off and the odometer light had shut off again. There are two places that water enters the fuse panel. One on a seam of the cowling and the other from the upper windsheild, to the door post, to the dash. The water runs down and runs into the back side of the relay / fuse panel, fills up the relay and voila, dead battery. In some f 150's of that era it turns on the heater, or the windsheild wipers. Running the battery dead, as I found out after spending 4 hours to take out and re install the starter. Seal up the seam under the cowling and or at the top of the wind sheild and you should be succesful.
Pete B
