Tonnue Cover help
Go Roll-top Dude!
i am looking at a few different covers and wondering what everyone thinks. i don't have much experience with these so i have no idea which ones are good. i want to be bale to use my whole bed quickly and easily when necessary. here are the ones i like
http://www.autoaccessoriesgarage.com...ge_hardhat.asp
http://www.autoaccessoriesgarage.com...jackrabbit.asp
http://www.autoaccessoriesgarage.com...ID=1003&vlink=
the last one is my favorite but i don't know about quality or anything like that. any and all help will be much appreciated. thanks
), you can get a hard top color matched cover (that's a PITA from my experience with a hard top cover on my first truck). So the question is "How much money do you need to put into a depreciating asset like a truck?" to get the same basic utility? The only negatives are that with my rear slider open, there's a little noise from the vinyl in the back since the last time I stretched it about 3 months back. I haven't tightened up the tension adjusters lately though (which are built into Access covers by design since all vinyl stretches more or less eventually). I just need to remember to tighten it the next time I've got it rolled open is all and pull the velcro tight on the sides and it's fine.
Tim
I just installed the Extang Revolution.
The cover was very easy to install and operate.
I also received a free tail gate seal with the order from Autoanything.
As far as keeping water out, it does a do a good job. I did have a small amount get it but it was very little, I may have to look at how I installed the seal. It also may have gotten in around the top of the tail gate. But again it was a very small amount, not enough to worry about.
As for removal, of course the side rail stay attached but you can easily remove the cover in a matter of seconds if you need to. Just loosen the one screw and lift the cover (of course after its rolled up and straps are attached).
I reall like the low profile this cover has!!
There are a couple of pics in my gallery of the cover.
http://www.extang.com/docs/revolution.html
Archer
Archer
Convenience and Security are competing objectives.
I have a lund 3-fold vinyl cover and it's very, very convenient, I almost never have to take it off but, when I do, it's (literally) a 2-minute operation and I can sling it around with one hand... but it's only a box cutter away from uselss (security wise).
There's lots of people happy with their undercovers but... what do you do with the g-dam thing if you need to use the bed? Take it off. Leave it at home. Not very convenient. And if you happen to impulse buy major home appliances a lot... forget about it.
I like the jackrabbit but, again, if you need the whole bed... what do you do?
After close to 4 1/2 yrs. my PE Jackrabbit cover is starting to show it's age. Also it always had a slight leak where it met up to the tailgate. Low profile and has good look's but could have been built better for the price. Around 800 buck's.
