SuperCrew
2002 Rear Brakes
Old Apr 18, 2008 | 11:22 PM
rls270's Avatar
2002 Rear Brakes
I'm just looking for advice on changing the rear brakes pads/rotors on my screw. Do i have to lossen the parking brake up to remove the rotors and how do I adjust the parking when I'm done. Right now the parking brake isn't working to good.
I changed the front pads and rotors tonight and am going to hit the rears in the morning. The 3rd BFH was the trick to get the front rotors off after penetrating oil and heat.
Old Apr 19, 2008 | 06:15 PM
wookie13's Avatar
no just take the calipers off and remove the rotors-the parking brakes are inside of drums on the rotor hats when you in there i would inspect/clean/adjust if nesscary the parking brake shoes if you use it a lo
Old Apr 24, 2008 | 02:06 PM
LittleTow's Avatar
Were you able to simply pull the rears off? When I did my rear pads the rotors didnt want to come off even with a few SOFT taps with a rubber mallet.
