08 SCREW LIFT?? OR LEVEL IT Picts plzz
Originally Posted by David95xj
Those Total Chaos ones look pretty slick. so what actually makes the truck level? 1.5 or 2.5? I have a 4wd FX4 package super crew.
I'd like to run stock rims ( I love the FX4 ones) and I like the stock look with taller possibly skinnier tires.
What is the equivalent of a 33 or 35 inch tire for an 18 rim?
I have the 5.5' bed and the 1.5" kit has me .5" higher in the back, which is what I wanted. I went with 295/70/17 Nitto Terra Grapplers, which are just a tad bit larger than 33's. The 2" kit would probably be perfectly level. There are slight variations between model years/trim levels, and different people has slightly different results. It may also depend on the kit you choose. The most popular one around here seems to be the Auto Spring.
Yea i am in the same boat. I want to get bigger tires but i also want to be able to fit into a parking garage. I was thinking about the two inch lift with 33 or 35 Does anyone know what the exact measurement of a FX4 with 33/35 and a 2 inch lift is?
