SuperCrew
2003 Supercrew Turn Signals
Old Aug 23, 2007 | 08:23 PM
Super6's Avatar
Question 2003 Supercrew Turn Signals
Both turn signals just stopped working...emergency flasher still operates...Checked fuse No. 13 in fuse box beneath drivers side dash...Appears to be o.k.... Is there a seperate relay for the turn signals or is it built into the Multi Function Switch on the column? Have not had the bulbs out to check those out yet. Both sides stopped same day so not leaning towards a bulb.. Thanks in advance.....
2003 F-150 4x4 auto
Air Raid Cold Air Intake
Magnaflow with side dual exit
SCT tuned by Innovativediesel.com
Old Aug 24, 2007 | 07:52 AM
Super6's Avatar
Just located the problem...Moved the tilt wheel to a different position and apparently wasn't locked....Works fine now... Thanks Anyway...
2003 F-150 4x4 auto
SCT tuned by innovativediesel.com
