SuperCrew
squeeking somewhere in the driveline?
Old Mar 31, 2007 | 09:07 PM
jswford's Avatar
I have developed a type of squeek somewhere. I have changed the u-joints, repacked the left front wheel bearing, taken off the clips from the brake pads. I cant figure this one out. it does it while in gear with the truck moving, if i go to slow it stops and usually i cant get it to do it again until the speed gets back up to around 30-40. If i put it in neutral and rev it the pitch does not change. If i steer left to right the pitch does not change. It only changes if i slow down. Help!
Old Mar 31, 2007 | 10:37 PM
WildmanNP's Avatar
It may be a cv joint that's going out.How's the rubber on the joint,there may be sand or dirt in it.You didn't say the mileage on your truck and if it was 2 or 4 wheel drive.Also it may be a bad idler pully.I had one a FORD van and thought it was the alt bearings going out.Good luck on finding it.there's alot places for a squeek hide.
Old Apr 1, 2007 | 08:48 AM
jswford's Avatar
2wd. 76000 miles.
Old Apr 1, 2007 | 09:14 PM
screwtech02's Avatar
Possible rear E-brake squeek??? Seen the cables hang up, and cause it....
