SuperCrew
Change tranny fluid or not
Old Mar 12, 2007 | 08:52 PM
Dingo's Avatar
While servicing my 01 Screw, checked the tranny fluid, and it was completely at the top of the dip stick. I think it was serviced when I bought it, but not sure! the truck has 50k on it. 5.4 , fx4. don't know what transmission I have. If I do change fluid & filter, how much MercuronV fluid do I need?
Old Mar 12, 2007 | 09:16 PM
mgsalida's Avatar
IIRC, the trans is probably a 4R70W and I believe the capacity if draining the torque converter is somewhere around 10 or 11 quarts. If you are just dropping the pan, I think you will need about 4 or 5 quarts.
Mike
Old Mar 17, 2007 | 10:35 PM
geicocaveman's Avatar
I'd just take it in and get a full flush. Its worth it vs. time and effort against doing it yourself.
Old Mar 17, 2007 | 11:02 PM
cpaggie_07's Avatar
I'll agree with having the tranmission flushed. I did a tranny flush for my 30K mile service, just for the sake of maintenance even though the fluid looked great before the flush. I noticed some better driveability afterwards.
Old Mar 18, 2007 | 07:26 AM
Dingo's Avatar
The guys at the local parts store gave me filter made in China. No Way was that thing going in my truck! So it was quickyl returned. I only had to show the manufacturing country to get a refund. Back to the dealer! So is there any way of knowing for certian what tranny I have? Serial#or vin#???
Old Mar 18, 2007 | 11:15 AM
mgsalida's Avatar
You might try looking at the Veh Certification Label (drivers side "B" pillar" or drivers door) for the trans code. The info below is for my 2003.
7 - four-speed automatic (4R100), heavy duty
E - four-speed automatic, E4OD (4R100)
M - five-speed manual overdrive (Mazda M5R2-C)
U - four-speed automatic, AODE (W/4R7OW)
Mike
Old Mar 18, 2007 | 08:59 PM
Dingo's Avatar
Is this the number you're talking about mgsalida? If so, is it a W/4R7OW?
Old Mar 19, 2007 | 08:55 PM
mgsalida's Avatar
Dingo:
Yes, that is the trans code. You indeed have the 4R70W trans in your truck.
Mike
Old Mar 19, 2007 | 09:26 PM
Dingo's Avatar
Thanks for the info. All I need is my filter. Again Thanks!
Old Mar 19, 2007 | 10:19 PM
mgsalida's Avatar
Also, just for the heck of it, you also have the 3.55 L/Slip (H9) rear end gear.
Mike
Old Mar 22, 2007 | 12:13 AM
screwtech02's Avatar
For what its worth, and as far as i know, ALL supercrews from 01-03 will have a 4R70W in them. Have yet to see a 4R100 or a stick tranny as a option.
