SuperCrew
100K maintenance
Old Dec 20, 2006 | 01:12 AM
ZelenVR's Avatar
Question 100K maintenance
So I'm about an oil change away from 100K on the odometer and would like to keep this truck for another 100K. After that I think I'll garage it and save up for a hover conversion.
Anyway, was wondering if there was a good preventative maintenance checklist anywhere that I could use to go through the truck bumper to bumper. If not maybe we could start one here, would be a nice reference to have around I think.
Toward that end lets assume that nothing has been done save for the regular oil change and tire replacement. Also lets assume that its a 4x4, since that would cover anything on a 4x2 as well.
So who wants to start?
Old Dec 20, 2006 | 07:22 PM
F151's Avatar
Spark plugs.
Old Dec 20, 2006 | 08:43 PM
ws6_guyscrew's Avatar
always keep up to date on regular maintaincence for it to live a long & happy 200k miles.
Old Dec 20, 2006 | 09:22 PM
F151's Avatar
Yeah, if you didn't do a tranny service at 60k, it won't matter now. So the important thing is to keep up with the maintenance at the proper intervals. There is nothing special at the 100k mark that you wouldn't do at the 20k.
Old Dec 22, 2006 | 11:08 AM
sx460's Avatar
I think that's a really cool idea and we should definetely write something up. Here's some ideas, obviously if they were done recently no need to do many of them again but here's some things to at least check over:
- Oil & Filter Change
- Spark Plug / Wires Change
- Transmission flush
- Power Steering flush
- Coolant flush
- Brake fluid flush
- Rotate tires (check for balance and pressure)
- Check belts
- Check hoses
- Timing belt check
- Battery check / replacement
- PCV valve replacement
- Fuel system treatment
Old Dec 25, 2006 | 05:22 AM
Ford390pwr's Avatar
Exclamation Maintenance schedule.....
I would reccomend that you check the following link:
https://www.fleet.ford.com/maintenan...les/GetYMM.asp
This is an awesome resource for Ford vehichles up to 150,000 miles. You can try to enter your vin, but it worked better for me to just choose the vehichle information.
Hope this helps.
