SuperCrew
Figure This Out
Old Nov 21, 2006 | 10:25 AM
Big Daddy Whiteboy's Avatar
Figure This Out
ON RETURN TRIP HOME CHECKED COMPUTER TO SEE HOW MANY MILES LEFT TILL EMPTY TO GAUGE IF I COULD MAKE IT HOME. MILEAGE TO HOME WAS 70 MILES. COMPUTER SAID 100 MILES TO EMPTY. 45 MILES DOWN THE ROAD WARNING BUZZER GOES OFF AND SAYS LOW FUEL WARNING. I CHECK TO SEE HOW MANY MILES LEFT AND IT SAYS 0 MILES TILL EMPTY. WHAAAAAAAAT? FIGURE THIS ONE AND I'LL SEND YOU SOME FRESHLY KILLED DEER SAUSAGE. OUT. LATE. B.D.
Old Nov 21, 2006 | 10:45 AM
ncaissie's Avatar
The meter tels you how much you have left but it calculates using your current speed and acceleration. So if you speed up it gives you a different reading.
You should also have one that tells you the current consumption.
Put that on and floor it and you will see it change.
Old Nov 25, 2006 | 05:14 PM
f-150sport03's Avatar
On my dad's truck (2001 F-250 SD 4x4 diesel lariat)--same deal. I think part of the problem is that the fuel gauges in Fords are kinda' cooky. Whenn I start driving, they show a little less fuel than when I'm about 10 miles down the road. Then, the gauge drops at a normal and consistant rate.
Old Nov 25, 2006 | 08:01 PM
RacingJake's Avatar
Sounds about right. When the low fuel lite glowed you still had a few more gallons in the tank and most likely could of made that 100 mile mark before sucking air. Cause if she's still running it's not empty
I think the computer stuck in Kilometer mode
Old Nov 25, 2006 | 08:17 PM
Jbrobeck's Avatar
My mountaineer was very similar in how it worked. Its basically just a running average, hills, wind, heavy accelleration and just plain sensory error makes the computer more of a suggestion than a fact! When my low fuel indicator came on, it would automatically say 50 miles till empty, but I could usually get 60-70 and still have a bit in the tank. Just one of those anomoly's
Josh
Old Nov 25, 2006 | 08:25 PM
I can't figure that out, nor can I figure out why you're yelling at me.
Old Nov 25, 2006 | 08:57 PM
ive gone over 65 miles of city driving after my low fuel light came on.
we had a rented dodge caravan and the light came on and it took us forever to find a gas station, and then sat at a few lights before we finally got there and we put in 22.9 gallons on a 23 gallon tank
By the way seems your caps lock is on
-Patrick
Old Nov 26, 2006 | 03:32 AM
ws6_guyscrew's Avatar
ha tomorrow i'll have my own deer ( hopefully, and hopefully a 12pt )
But I've never really messed with that, when it looks like you have just enough to make it, you'll get screwed I just always hit the Quick Fill when I see one.
Old Nov 27, 2006 | 02:18 PM
NAH CAPS LOCK IS NOT ON. THATS JUST THE WAY WE TALK. BY THE WAY I'LL TAKE A YOUNG SPIKE OR YEARLING DOE ANYTIME OVER ONE OF THOSE 12 POINTERS. MEATWISE THAT IS. MAY LOOK GOOD ON WALL BUT TOUGH TO CHEW. JUST MY OPINION. AND WHEN I WANT YOURS I'LL GIVE IT TO YOU. OUT. LATE. B.D.
