SuperCrew
MPH vs RPM
Old Sep 13, 2006 | 10:41 PM
RacingJake's Avatar
MPH vs RPM
I got a 02 Screw with 5.4, 4r70 trans, 3.55 gearing and stock tires. With overdrive on at 70mph my rpm's are at 2K. Does this sound normal, or are you guys getting something else.
Jake
Old Sep 13, 2006 | 11:04 PM
72 mustang's Avatar
same as yours
Old Sep 14, 2006 | 01:03 AM
edisonrizon's Avatar
Jake
Just answer you with another question: What do you expect with your specs?
P.S. This quote brings me to 200 posts!
Old Sep 14, 2006 | 01:36 AM
zx12-iowa's Avatar
Yes your tach is correct. Mine was like 73 or so mph at 2K
Old Sep 14, 2006 | 06:52 AM
APT's Avatar
APT
What stock tire size do you have? Engine speed is a function of transmission gear ration, differential gear ratio and tire size. Overdrive is 0.70:1. Google will find you many a gear speed calculator.
Old Sep 14, 2006 | 08:48 AM
whitecrystal1's Avatar
I don't know if this will help or not. http://www.ring-pinion.com/content/calculators/RPM.asp
Old Sep 14, 2006 | 09:52 AM
RacingJake's Avatar
Just seeing if my truck is in the ball park with all you other Ford Heads out there
This way if it does change I know something is going on with the trans or lockup.
