SuperCrew
what lift kit should i get?
Old Sep 10, 2006 | 06:45 PM
luis 6's Avatar
what lift kit should i get for my truck and how many inches cuz i really dont know what to do. well need some help here. and i need one not to costly. if u know what i mean?
thanks
Old Sep 10, 2006 | 10:35 PM
wandell's Avatar
It's completely up to you. I'd suggest taking a look around here at some of our trucks and make a educated decision based on what you want. Just rememer, the taller you go and the larger the tires, the more money it cost. You can buy a 3 inch body lift for about $150 or you can spend $2000 on a suspension kit. Your wallet and imagination are your only limits.
Old Sep 11, 2006 | 09:42 AM
Quackaddict's Avatar
My personal opinion is if you want 33's go with a 3" body lift and if you want 35's go with a 6" suspension lift.
I believe you can fit 35's with a body lift bu I don't think it looks right.
One day I am going with the 6" 35 option.
Old Sep 11, 2006 | 02:17 PM
luis 6's Avatar
thanks. and where can i get a body lift at? and if i get that then later on i can get the suspension lift? or what would look better?
Old Sep 11, 2006 | 04:33 PM
wandell's Avatar
You can buy a Performance Accessories body lift just about anywhere that sells truck accessories. Yes, you can combine a suspension and body lift.
Old Sep 11, 2006 | 04:58 PM
luis 6's Avatar
ok well is it hard to put on my truck?
Old Sep 11, 2006 | 05:00 PM
wandell's Avatar
Body lifts are time consuming tedious work, but they are not hard to install. I installed mine in a weekend, but I was working by myself most of the time.
Old Sep 11, 2006 | 05:02 PM
luis 6's Avatar
ok so this should run me between $150 and????
Old Sep 11, 2006 | 05:08 PM
luis 6's Avatar
and if i get the body lift. do i need to get the leveling kit. and can you plz school me on this? cuz ok i need to know what to put on my truck and what that part does? thanks
Old Sep 12, 2006 | 10:49 AM
wandell's Avatar
The PA body lift is around $150 for the kit. Installation cost will vary if you can't install it yourself.
Do you have a 4x2 or 4x4? If you have a 4x4, you don't need a leveling kit because your front ride height is adjustable by changing the preload on your torsion bars.
