SuperCrew
Need Better Acceleration
Old Apr 29, 2006 | 04:53 PM
Jim McK's Avatar
I expect to buy an 06 Lariat Supercrew in the next week or two. Having road tested a few already, I find myself wanting a little better power/torque.
What would be the first things you F150 afficianados suggest for performance mods?
Old Apr 29, 2006 | 05:17 PM
FX4 Matt's Avatar
Registered User
Call Troyer performance or check out www.troyerperformance.com and get you an Xcal2 and AF1!, I have an 05 crew 15.3s in the 1/4
Old Apr 29, 2006 | 09:21 PM
jpdadeo's Avatar
My personal recommendation is a Troyer Performance custom tuned XCal2. I’ve been running Mikes custom tune for 14 months, without a single problem
Call Troyer Performance when you order because all F150online members get a discount; all they do is verify your F150online screen name
Mike’s custom tuning made my truck fun to drive; more responsive, better fuel economy, etc, etc, etc
Old Apr 30, 2006 | 12:39 PM
inurok's Avatar
Any tuner you get will make it mush more enjoyable to drive..
Old May 1, 2006 | 04:34 PM
Jim McK's Avatar
I was just scoping out the Troyer website and the Stage 1 or Stage 2 setup looks exactly like what I want. Now all I have to do is give them a call and see if they do installations. I hate messing with this stuff myself. I just wanna drive...
Old May 1, 2006 | 04:47 PM
Lumadar's Avatar
If you want to be able to get up and go, the biggest and best mod under $1,000 (Or $5,000 for that matter) is to regear the truck. I went with 4.1s and it is a LOT better, but if you really want to take off try the 4.56s.
It should run between $600-850 for a 2wd, and about $1,400 for a 4wd.
Then go for the intake, exhaust, and Xcal2 from Troyer and you will be set. that's what I did and my truck is a LOT quicker than stock.
Old Sep 24, 2007 | 11:14 PM
jmcF150's Avatar
What exactly do the new gears do to make it accelerate better
Old Sep 25, 2007 | 07:44 AM
INFireRedF150's Avatar
Higher gear ratio(4.56:1 vs 3.55:1) let the engine breathe better and get into higher rpms faster, and lets the engine work less to get the same weight moving up to desired speed.
Best way to see the difference is get into a vehicle with a stick shift, put it in 3rd or 4th and try to take off vs putting the stick in 1st.
Old Sep 25, 2007 | 09:23 AM
APT's Avatar
APT
Troyer Stage 1 kit is great for performance gains. The custom cals will improve sihfting, spark advance, and take advantage of more energy in premium octane fuel. If you have a 2wd truck, a shorter rear axle ratio will be cheaper. It helps acceleration by changing the number of times the engine spins compared to the tires Just as 3rd gear accelerates quicker than 4th gear, so will a shorter axle ratio (numerically higher).
Old Sep 25, 2007 | 10:06 AM
jpdadeo's Avatar
It's all about Torque multiplication; if the motor gets to turn 14.25 times in order to only turn the wheels once, the amount of torque the motor is applying to the wheels gets multiplied that many times
