SuperCrew
Big electrical problem
Old Apr 24, 2006 | 06:13 PM
Screw-Jake's Avatar
Been a while since i have been on but here is my major issue. I lost my cluster gauge lights and all of my parking lamp lights. All I have are headlights, highbeams and brake lights. My interior lights work but just not the cluster guage lighting. Everything else appears to be working except the speaker that tells you you left your lights on, that only works of the keys are in the ignition not if you leve the lights on. Any suggestions before I end up spendign big money at the dealership? I checked the fuses but they all seem to be fine, no burnt ones found. I think I did it when I was working on my LED taillights but I don't remember crossing any wires.
Old Apr 24, 2006 | 09:30 PM
Gearhead99's Avatar
You blew the fuse for the inst. lamps. They are tied to the tail lamps too.
Old Apr 25, 2006 | 01:01 PM
Screw-Jake's Avatar
That fuse is not burnt out though, any other possibilities
Old Apr 25, 2006 | 07:21 PM
screwtech02's Avatar
Been raining alot where your at??? Sounds like possible water intrusion into the fusebox/gem module to me....
But, i could be wrong....
Old Apr 25, 2006 | 08:49 PM
Screw-Jake's Avatar
I checked all of the fuses again today and I have no power at all to fuse 18, 21 & 22. 18 is the interior light tail lamps, anyone know where I can go from here and should I just try to run a new power to that feed.
Old Apr 28, 2006 | 03:18 PM
Screw-Jake's Avatar
All fixed, thanks for the responses
Old Apr 28, 2006 | 08:13 PM
TruBluSuperCrew's Avatar
So what ended up being the problem? Just curious.
