Where does the code reader plug in?
I could be wrong, but I beleive that it may be the plug port that is underneath your steering column. If you stick your head down there you will see a port thats fairly easy to get too. Good luck.
Using this picture :
Just below the anti-submarine panel, there is a black D shaped plug. It shows in the picture as if it was above the gas pedal. Black with 7 silver dots showing. That is the DTC connector.
Make sure you cigar lighter works, as this powers the DTC port, which in turn powers the scanner.
