Configuring wiring from truck to camper
I recently bought a 2001 Screw that I want to pull a camper with. Since I bought it used, I did not get a manual with it. I am having trouble connecting my receptacle from my truck to the wiring on the camper. All the lights work on the truck, but on the camper everything works except the left turn signal. The left turn signal on the truck works, so this is very confusing. Any ideas?
Take a look at fuses 19 & 20 in the power distribution box under the hood. #19 is for the right brake and turn lamp (trailer circuit only) and # 20 is for the left brake and turn lamps(trailer circuit only)
Send me your email address and I'll email you the 2001 owners manual in a PDF file.
Thank you so much for the advice. I really appreciate your time and expertise in this situation. My husband has been working on this all day. I will let you know if this works. My husband says that it is probably that because the brake light did not work either. I would really appreciate you sending me the manual via e-mail. My address is cajunroots@bellsouth.net. Thanks again.
